Heavy_Stoke Posted May 17, 2015 Share Posted May 17, 2015 I have all 8-fs set and have the expression pedal set for volume control and it will not set to a min of 0. Every time I try my guitar what should be 0 I can still hear my guitar. I have comp on 1, screamer on 2, pitch glide on 3, delays on 4,5&6 reverbs on 7&8. even with all fs off and the pedal in the off position i still get volume. I've tried setting to minimum of 0 with Edit but nothing seems to work. I've tried setting it to 0 manually via the pod itself. ...still nothing. Anyone have any ideas or fixes? thanks in advance. Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted May 17, 2015 Share Posted May 17, 2015 Unfortunately, 0 doesn't always mean mute. I don't use the VP except on rare occasions, so I can't speak from first hand knowledge. But there have been posts about it before. See if this one helps: http://line6.com/support/topic/12828-amp-volume-control-problem/ Quote Link to comment Share on other sites More sharing options...
Dshow Posted May 17, 2015 Share Posted May 17, 2015 Have you tried to calibrate the pedal? http://line6.com/support/page/kb/_/pod/pod-hd500-hd500x/pod-hd500xhd500-pedal-calibration-r161 Quote Link to comment Share on other sites More sharing options...
duncann Posted May 17, 2015 Share Posted May 17, 2015 What does your signal chain look like? Are you using both paths? How is your inputs setup configured? What do the mixer controls look like? If you can, post a screenshot, or post the patch. There are some configurations where sound will still come through even though things are apparently muted. Quote Link to comment Share on other sites More sharing options...
