titchyblackcat Posted May 21, 2015 Share Posted May 21, 2015 Can I record the using the Audio outputs one type of amp on the right and another type of amp on the left ? Quote Link to comment Share on other sites More sharing options...
spaceatl Posted May 21, 2015 Share Posted May 21, 2015 Yes you can. Basically, setup a Dual-Amp tone and using the mixer pan controls, set pan A Left and pan B to the right....A will be your Left out and B will be right....You can also monitor that in the headphones... Quote Link to comment Share on other sites More sharing options...
titchyblackcat Posted May 21, 2015 Author Share Posted May 21, 2015 Thanks for your help, I was hoping that would be the case as i'm going for a clean but "BIG" rythm preset. Quote Link to comment Share on other sites More sharing options...
joel_brown Posted May 22, 2015 Share Posted May 22, 2015 Sometimes using a Digital Delay between the L and R channels set to 20ms can give it a larger sound. Example: www.ChildrenOfTheGraveBand.com/BlackSabbath.hbe The above example is only to demonstrate the delay between L and R channels. Otherwise it is a hi-gain patch designed for use into the FX return of a pair of tube amps. Quote Link to comment Share on other sites More sharing options...
