Rsalyerds Posted June 17, 2015 Share Posted June 17, 2015 Hey guys, I'm posting this here because line6 no longer makes these and didn't know where else to post so sorry in advance. I have an old flextone III 2x12 combo with short board. I love it, but I recently started playing in my church worship band so I picked up a TC electronic nova delay. If I use it with effects loop the nova pedal only works with clean channels. If I switch to an overdrive/distortion model I get nothing, almost as if the amp is rejecting the outside pedal. If I run the pedal straight through it works fine. Any help is appreciated. Quote Link to comment Share on other sites More sharing options...
arislaf Posted June 24, 2015 Share Posted June 24, 2015 Did it happen to update your flextone? I have mine FL3 XL and working fine with ext. pedals. Just a blind shot in case. Quote Link to comment Share on other sites More sharing options...
spaceatl Posted June 27, 2015 Share Posted June 27, 2015 This might be FX/Settings defaults....I still use my old Flexy and as I remember there is a setting in the Flextone that when you select an Amp model, it will load the default FX and such for that model...The fx Loop also has a pre and post setting that can only be gotten at thru Edit...If I remember correctly, this setting can be disabled in the Edit application....It has been years since I edited my Flex with the PC app, but I think that is where you want to start....The deep edit really helps get the most out of the amp Quote Link to comment Share on other sites More sharing options...
