Line 6 POD HD Pro x - External Effects Loop in Signal Chain
seancsmith89
HI all,
Currently looking i investing in the Rackmounted Line 6 POD HD but there is an issue I would like to clear up before I purchase.
I am currently using an old Boss GT-8 which is absolutely diabolical in terms of sounds.
I set up in the 4cm so that I can place certain effects before and after the preamp (Marshall JCM 2000 DSL).  When I set up the signal chain, I can place the pedals external effects loop into the chain as an active component.
 IE:  WAH>>VOLUME PEDAL>>OVD>>(Unused inbuilt preamp simulators)>>EQ>>EXTERNAL EFFECTS LOOP>>CHORUS>>DELAY>>REVERB
All of the above are interchangeable so I can have any signal chain I wish.
My worry is, that, from the online videos I have looked at, and a quick glance of the manual, I cannot figure out where the external effects loop in in the POD's signal chain.
Am I missing something here?
It is not a default block like the amp / pre amp block is. You have to add it to your signal chain like other effects.
