Stratotron Posted July 23, 2015 Share Posted July 23, 2015 When I connect my expression pedal, it takes over the volume/wah. Is there a way to set the default so the expression pedal is always assigned to "tweak" mode, or do I have to go patch by patch and assign the expression function? I want the volume/wah onboard pedal to remain assigned to vol/wah when I connect the expression pedal' Quote Link to comment Share on other sites More sharing options...
Stratotron Posted July 24, 2015 Author Share Posted July 24, 2015 My own reply...not at all happy with the expression pedal. It seems wrong for the expression pedal to take over the on-board pedal. The secondary let down is the throw of the expression pedal. Too much of the effect is at the end of the throw, and can't be compensated by adjusting the toe-heal values. Don't like the idea that if I want to use the expression pedal to tweak one function, in one patch, I have to configure it in every other patch because it overrides the one board pedal. There should be a global switch to configure the relationship between pedal 1 and pedal 2. I attempted to use the expression pedal as the default volume...In my opine, mechanically it stinks. BTW it is a line 6 pedal. Quote Link to comment Share on other sites More sharing options...
mcbeddall Posted July 24, 2015 Share Posted July 24, 2015 There are different modes when setting up an external expression pedal, have another look at the manual I can't explain it any better than its already written but it seems you can specify that the onboard pedal always does wah and the extra pedal does tweak Quote Link to comment Share on other sites More sharing options...
stevekc Posted July 24, 2015 Share Posted July 24, 2015 For most flexibility - for "PEDAL MODE" I set this to "TWEAK with PEDAL 2" = the most functionality for meSee table below: Quote Link to comment Share on other sites More sharing options...
