kittisiri Posted September 18, 2015 Share Posted September 18, 2015 I'm a beginner so this maybe a dumb question I don't know. Can anyone explain a little bit about it ? Thanks a lot, Duke Quote Link to comment Share on other sites More sharing options...
phil_m Posted September 18, 2015 Share Posted September 18, 2015 There's no real danger of damaging something or anything like that, but if the signal going into the front of your amp is too hot, you could clip the input or cause unintentional clipping down the line. When I use to run a POD in front a tube amp, I would actually run the signal a little hot just because I thought it sounded a little better. Quote Link to comment Share on other sites More sharing options...
kittisiri Posted September 18, 2015 Author Share Posted September 18, 2015 Thanks Phil. So you mean you actually prefer setting the output mode to LINE when you connect to tube amplifier, right ? Quote Link to comment Share on other sites More sharing options...
phil_m Posted September 18, 2015 Share Posted September 18, 2015 Thanks Phil. So you mean you actually prefer setting the output mode to LINE when you connect to tube amplifier, right ? Sometimes I do, yes. Quote Link to comment Share on other sites More sharing options...
Jazzmandan Posted September 18, 2015 Share Posted September 18, 2015 Not explained at all in manual?? My understanding is the Line out signal incorporates speaker emulation in the amp sounds, whereas if you use the Amp Out to your amp you would not need this. That is the way it was in my old POD. But you can let your ears tell you what you like best. Quote Link to comment Share on other sites More sharing options...
