StudioTM Posted September 22, 2015 Share Posted September 22, 2015 Or do you recommend another expression pedal? Quote Link to comment Share on other sites More sharing options...
phil_m Posted September 22, 2015 Share Posted September 22, 2015 Yep, it's compatible. Quote Link to comment Share on other sites More sharing options...
StudioTM Posted September 22, 2015 Author Share Posted September 22, 2015 Yep, it's compatible. Thanks! Quote Link to comment Share on other sites More sharing options...
ColonelForbin Posted September 23, 2015 Share Posted September 23, 2015 Get this one if you prefer a more 'wah pedal' feel: http://missionengineering.com/?product=ep1-l6 Quote Link to comment Share on other sites More sharing options...
duncann Posted September 23, 2015 Share Posted September 23, 2015 Get this one if you prefer a more 'wah pedal' feel: http://missionengineering.com/?product=ep1-l6 I just picked one of these up from Sweetwater (last one they had). It's really well built and works with HD units, likely Helix as well. The only thing I wish companies who make pedals like this would do is state explicitly the amount of physical travel their pedals have (what's the correct term form this?). I'm used to the pedal on my HD500X which has quite a bit more travel than the EP1-L6. I was unprepared for this and it's going to take some getting used to because the value changed is quite large when used as a wah or volume for very small movements of the pedal. Quote Link to comment Share on other sites More sharing options...
billlorentzen Posted September 25, 2015 Share Posted September 25, 2015 The EX1 is compatible, but as a disappointed owner of one, I can tell you it is not a quality unit. It's quite inaccurate; you can rock it back and it may or may not go to zero. The design is really poor. It is cheap though. I would like to see L6 offer a quality pedal to go with their excellent modelers. Quote Link to comment Share on other sites More sharing options...
phil_m Posted September 25, 2015 Share Posted September 25, 2015 I for one can't disparage the EX-1 too much. Yes it's plastic, and know it's not going to survive being run over or being thrown around. But it does the job. I have two of them, and one I've owned since 2000 and the other since 2003 or thereabouts. Besides guitars, I don't think I actually have owned any other piece of gear as long as them that has seen continuous use. Not bad for inexpensive pedals. Anyway, if you want to use other pedals, it's very easy with Helix. It has an auto-calibration feature for external pedals, so it should work with just about any potentiometer-based pedals. So in that sense, I don't know if there's a lot of incentive for Line 6 to make its own line of more expensive expression pedals. 1 Quote Link to comment Share on other sites More sharing options...
agnaema Posted September 3, 2017 Share Posted September 3, 2017 Wich one is compatible with the fbv3 ? Quote Link to comment Share on other sites More sharing options...
vcuomo Posted September 5, 2017 Share Posted September 5, 2017 Wich one is compatible with the fbv3 ? Both the Line 6 EX-1 and the Mission Engineering EP1-L6 should be compatible with the FBV3. Quote Link to comment Share on other sites More sharing options...
agnaema Posted September 10, 2017 Share Posted September 10, 2017 Both the Line 6 EX-1 and the Mission Engineering EP1-L6 should be compatible with the FBV3. Thank. I'm gonna try it. Quote Link to comment Share on other sites More sharing options...
