guybaye Posted October 5, 2015 Share Posted October 5, 2015 hi everyone, 1. i wanted to know if i can save sounds on 1A and 1B, i mean, to remove the current sound from there and switch for sounds i like more than it. 2. i wonder if i can play various of sounds with the looper.. i mean, playing dist', record it. then switch to delay with OD and record it like that, then add mod for example, and on and on... looking forward for an answer.. thanks and good day! Quote Link to comment Share on other sites More sharing options...
mcbeddall Posted October 5, 2015 Share Posted October 5, 2015 Yeah you can do all that Quote Link to comment Share on other sites More sharing options...
Jazzmandan Posted October 6, 2015 Share Posted October 6, 2015 Not sure about Item 2. Yes, you can loop any effects and patch, but when you play over that loop you have to use the same patch. You can't change to have the loop as a simple clean sound and then play over it with a dirty sound. At least that is what I have found. Quote Link to comment Share on other sites More sharing options...
silverhead Posted October 6, 2015 Share Posted October 6, 2015 I believe you can loop using two different patches. You just need to make sure that both patches have the same FS assigned to the Looper, and that it is turned on in both. I don't have my Firehawk at hand to test this right now but I recall doing that some time ago. While the looper is playing back a loop recorded with one patch you can switch to the second patch and the loop will continue to play. You can then engage the overdub function and record with the new patch on top of the existing loop. ... at least that's what I recall..... if not accurate please correct me. Quote Link to comment Share on other sites More sharing options...
mcbeddall Posted October 6, 2015 Share Posted October 6, 2015 Yeah that's how it works for me too, but I haven't tried it since the update Quote Link to comment Share on other sites More sharing options...
