lordalladin Posted October 15, 2015 Share Posted October 15, 2015 Is there any way of controlling the total output volume of the Helix using the onboard expression pedal. In other words being able to control all patch volumes with the expression pedal. Quote Link to comment Share on other sites More sharing options...
Digital_Igloo Posted October 15, 2015 Share Posted October 15, 2015 Not globally, but it might be easier to just copy and paste a Volume pedal to the end of each one of your patches. The Volume pedal will stay in the buffer, so it's just a matter of paste > paste > paste. Quote Link to comment Share on other sites More sharing options...
SWoRd Posted October 15, 2015 Share Posted October 15, 2015 The problem is that you get the value that was set when you stored the patch, and it won't change until you move the pedal a little bit - then it will jump to the new value. You can also do it without using a block for a volume pedal, by controlling the level pareameter of the output block. It won't solve this issue though, but it will save a block. :) Quote Link to comment Share on other sites More sharing options...
Digital_Igloo Posted October 15, 2015 Share Posted October 15, 2015 The problem is that you get the value that was set when you stored the patch, and it won't change until you move the pedal a little bit - then it will jump to the new value. You can also do it without using a block for a volume pedal, by controlling the level pareameter of the output block. It won't solve this issue though, but it will save a block. :) Ah, gotcha. This has indeed been requested on IdeaScale. We already have the solution designed. 2 Quote Link to comment Share on other sites More sharing options...
bkunrath Posted October 30, 2015 Share Posted October 30, 2015 Hi Helixers, I#m recieved min yesterday a s a replacement of Native instruments Guitar Rig 5.2 on OSX. And it's sounding great, stability up to now better than then the totally outdated OSX version form NI! But I can't beleive what I'm readying here that an essential function is not avail!? Ooops, can't I really use an EXP as global volume instead/in addition to the manual Volume? Thats funny because I could even reprogram the whole Helix with my feet, but the typical stage thing of adjusting the volume I can't? Ciao, Bernd Quote Link to comment Share on other sites More sharing options...
garymwest Posted November 1, 2015 Share Posted November 1, 2015 Ah, gotcha. This has indeed been requested on IdeaScale. We already have the solution designed. Any idea when this will be added? More than one global eq would be handy, output volume could be mapped there also. Quote Link to comment Share on other sites More sharing options...
Joepeggio Posted November 1, 2015 Share Posted November 1, 2015 Any idea when this will be added? More than one global eq would be handy, output volume could be mapped there also. http://line6.ideascale.com/a/dtd/Multiple-global-presets/790099-23508 Quote Link to comment Share on other sites More sharing options...
