Helix (1.02.2) do not start anymore
sigitar
Thanks, that helps!
Unfortunately my presets are lost...
and my confidence is gone! When will this happen next time? Maybe during a gig?
I'm rather unsettled if I should keep the Helix, although I like many of the amp-sounds...
Mine did the same thing, I hard rebooted it and lost the presets I had been working on.  Seems there is an issue with the Helix PC software that it didn't save the bundle but did save the set list and I was able to get back my presets by importing the setlist I had previously saved.  Then went out and gigged with it and it has been fine since.
I assigned the Level-parameter of the Output-Block to a footswitch and named it "Level-Boost"
I did that in all my patches and had the black screen three times on the first day.
I only got the black screen on power up after a break though - not while it was running.
I did have it freeze one time while it was running, but that was fixed with a reboot without loosing all the presets.
Could it be related to assigning the pedal to the output parameter?
I did that to save a block for volume change.
