Assign same effect type to multiple footswitches
maxatla73
I haven't tried it, but it should be 'easy'.
As far as I can tell, in the app, you go to the effect block and then assign it to a footswitch, then choose the next effect block and assign to the other footswitch, and then keep going. Doesn't this work?
To change the FX type, select the desired FX block. In the top left corner of the FX display window hit the FX type icon. You will see all models of the given FX type, as well as the word Type in the same top left position. Hit the button that says Type. The display will change to a show the different FX type options (distortion, delay, chorus, reverb....). Select the type you want. The display will change again to let you select the FX model of the given type.
Then you can assign it to a footswitch as described above.
