venoms319 Posted October 31, 2015 Share Posted October 31, 2015 hii there just purchased a line pod pro hdx and setting it up and notice when adjusting the bass dial the screen shows it's out of calibration example if i turn to one on the knob it instantly says 69% but if i turn it 100% it reads fine same as at 0, also when say i set it at 40% it sits at about 70% but keeps flicking from daisy chain screen to edit knobs screen, not sure if anything can be done to fix this but much help would be appriciated. Quote Link to comment Share on other sites More sharing options...
Matt_Brown Posted November 2, 2015 Share Posted November 2, 2015 As far as I'm aware the patch 'saves'the level in it. The knobs then simply turn it up or down from the assigned volume. In this regard they won't ever line up, except by accident. This enables you to have different settings for different amps - something the knobs can't mirror. Quote Link to comment Share on other sites More sharing options...
silverhead Posted November 2, 2015 Share Posted November 2, 2015 There may be some dust or dirt in the knob shaft. Try rotating the knob from min to max rapidly many times; this may clear out the accumulated grit. If that doesn't work try some electronics contact cleaner. Quote Link to comment Share on other sites More sharing options...
