Relay G70 Case
angelojm
  • 4 weeks later...
Hi angelojm,
Unfortunately the TBP-12 case won't fit the G70 system due to its size. The TBP-12 case was designed for a headset/Lav system that has just enough room for two maybe even three transmitters. There currently isn't a case available for Relay but if you're looking on getting a case with the Line 6 brand on it, I personally use the "Line 6 Bag Compatible With The Pod HD500" which holds my system's and all of my cables that works out great for light travel to a demo, or a gig.
From reading it sounds like you have a Taylor, I'm assuming some sort of acoustic. From experience I recommend avoiding putting anything bulky like a wireless system in the front pouch of an acoustic guitars gig bag if possible. If too much pressure pushes against the pouch, it may result in damage to the guitar, so keep that in mind if room gets tight in that pouch. ;)
  • 1 month later...
Looking to get a case for my Relay G70.. Would a TBP-12 Bodypack Carry Case work? Also, I'm looking to fit it into my Taylor bag that has that large front pouch. Regardless, I just want a compact case for it.
Angelo
There should be a decent / small sized Mono case that would work well, and the quality on their gear is top shelf. I have the M80 tour sized case for my Helix.
http://monocreators.com/products/
  • 10 months later...
