StillErik Posted November 16, 2015 Share Posted November 16, 2015 Hi All, I'm having a problem with using my POD HD Pro for recording into Garageband that just recently began to persist and I have yet to find a solution for it. I'll describe my situation below, please help me if you can. Thanks! Setup: POD HD Pro Rack Garageband Macbook Pro (late '08/'09) OS X v10.10 (Yosemite) I normally record guitars and bass through my POD HD Pro rack and have just recently run into a problem with it. Usually, I'll plug in my POD via USB and in Garageband, it'll play through both sides of my headphones. Then, just a couple days ago, when I would pop the tuner on, tune up, then tap the tuner back off, the sound would be completely gone, not monitoring at all when there was just sound. So I would close my session, power off my POD, unplug, replug and turn it back on. Then it would work until I used the tuner again. I repeated this process a couple of times and then my POD began to only monitor through the right channel of Garageband. If I would pan the track hard left, there would be absolutely no sound. If I panned hard right, there would be the same amount of sound on the right from 100%-0% pan. Additionally, I removed the POD from the audio track and switched my input to the laptop's microphone and it monitors through both headphones as normal. Any ideas on why this is happening? I've plugged my headphones into the POD directly and it monitors through both sides of my headphones perfectly. Any help on this issue is much appreciated. Is it possible that a USB output setting on the POD glitched off by accident? Thanks, Erik Quote Link to comment Share on other sites More sharing options...
