rudomat Posted November 17, 2015 Share Posted November 17, 2015 i worked a while on it now, but i´m pretty shure now that helix isn´t always showing and playing the right stored levels... i´m using a volume/pan block at the end of the signal chain - right before the signal goes to my power amp (in 4CM of course....). i use it in gain mode and try to have every preset to recall at 0dB, so i store the preset in a 0dB position or go to 0 dB before storing, using the very left knob...i also store the unit to recall with the volume/pan block showing up, so i can control the actual parameters...in the controller assign menu, i store the min value of -120dB and the max value of +4dB, giving me the possibility to add a 4dB boost for solos...(are these actually really 4 dB boost what i´m hearing, or is it less...?) now when i switch between two presets, sometimes the preset recalls with +4dB, which it shouldn´t, for i stored it at 0dB, right...? then after going somewhere else and then returning, it recalls at 0dB, as it should...i guess that´s not ok, isn´t it...? and then again...some presets recall totally diffferent, and i also have no chance to make them do a 4dB boost with the pedal heal down...it´s acting like the pedal is not calibrated.. anyone else with such problems...? can i actually set the unit, so it recalls the actual state of the volume pedal when i change presets...? i´m getting a little frustrated at the moment...have the feeling, this unit isn´t really ready by now... Quote Link to comment Share on other sites More sharing options...
phil_m Posted November 17, 2015 Share Posted November 17, 2015 Right now, this is how the expression pedal and controller functions work. When you call up a preset, the value you're controlling goes to whatever it was when you saved the preset. It doesn't reflect the position of the pedal. This is different than how previous Line 6 products worked. Digital Igloo has said it will be changed to user-selectable setting in some upcoming firmware revision. Quote Link to comment Share on other sites More sharing options...
rudomat Posted November 17, 2015 Author Share Posted November 17, 2015 Right now, this is how the expression pedal and controller functions work. When you call up a preset, the value you're controlling goes to whatever it was when you saved the preset... ...now that´s what i thought...now i must say, this doesn´t really work constantly, so i´d guess that´s a bug....;-( as i said...sometimes, when i recall the preset, it comes with 0dB, sometimes with +4dB f.e... Quote Link to comment Share on other sites More sharing options...
