Have 2 amps in a patch
Mgregory623
Many ways to do it.  You can split the paths and use the A/B and assign a footswitch to send 100% to A then 100% to B when pressed.  You can have both amps one after the other and assign a footswitch to toggle one off and the other on.
There are literally endless possibilities. Go to Factory 2, patch 13D.  You will see a built patch with 2 amps and a switch. This one is a very simple one.
Just remember to press save once and change the save location so you don't lose the factory ones if you want to keep them.
