iainlclarke Posted July 31, 2013 Share Posted July 31, 2013 Hi Everyone I got a brand new pocket pod on the weekend and I think its broken... When i plug it in, it functions correctly with no background noise, but over the space of 1-2 minutes the background static noise increases from zero and becomes really loud. If i power off the unit for about a minute and plug it back in the background noise has gone and starts building up again. If i quickly power off the unit and on again the astatic noise remains is at the same level. I dont think its the guitar, because when i unplug the cable from the guitar end the loud static noise remains the same. I have tried changing batteries and doing a factory reset with no effect. Tried changing all possible settings including the noise gate. Changing settings on the pod does not effect the static noise level in any way once it has built up. Im guessing its some sort of electrical fault with the unit, unless anyone else has suggestions? I do not have a power adaptor to test it. Thanks in advance Quote Link to comment Share on other sites More sharing options...
Triryche Posted July 31, 2013 Share Posted July 31, 2013 I would try a new cable. If you unplug the cable from the guitar it is very typical to get static, especial with high gain. What if you unplug the cable entirely from the POD? If the noise goes away, that would suggest it is your cable. Quote Link to comment Share on other sites More sharing options...
djamdjazz Posted February 17, 2014 Share Posted February 17, 2014 Hi, I just purchase a pocket POD today and I have the exact same problem. At first, it works fine but after about 2 to 5 minutes, static comes gradualy and build up to a point where it is realy bothering and the guitar sound is fuzzy. This noise appear with batteries and also with AC adapter.the sound is still there if a USB cable is connected between the POD and a computer wether a guitar cable is connected in "guitar in" or not. That is not a cable problem : I have tried several cables, all working fine with the other piece of equipement I own, one of them being a POD XT Live. I'd like to know if you encountered this problem beside the post at the top of this topic? And is it a case of replacing the unit? Thank you for your help Quote Link to comment Share on other sites More sharing options...
djamdjazz Posted February 17, 2014 Share Posted February 17, 2014 Hi, I got the exact same problem with the Pocket POD I purchased today and i'm certain it is not a cable issue. What could be the problem? Is it a case of replacing the unit? Quote Link to comment Share on other sites More sharing options...
Clarkj-it Posted March 11, 2014 Share Posted March 11, 2014 2007 Pocket Pod after 5 months loud noise like bad ground. But amp works fine without Pod. Headphone noise.Did find if I crake to full volume one side can be heard the other noise. Called Line 6 again tommorow. Reset no good. Had already update firmware. Quote Link to comment Share on other sites More sharing options...
neilbriancastro Posted April 15, 2014 Share Posted April 15, 2014 I bought mine 2 days ago. I observed the same issue where the loud static builds up in a few minutes of playing and then goes away after leaving the POD un-powered for a few minutes. Anyone has resolved theirs? Quote Link to comment Share on other sites More sharing options...
neilbriancastro Posted April 15, 2014 Share Posted April 15, 2014 I am having the same issue. After a few minutes of playing, the fuzzy static sound increases (setting the effect back to clean does not produce a clean sound). If I leave the unit un-powered for several minutes then power it up again, the static noise is goes away and then comes back again after playing for sometime. Quote Link to comment Share on other sites More sharing options...
dprkk Posted April 7, 2015 Share Posted April 7, 2015 I have had the same problem with my Pocket POD since new. I've wrote up two tickets to LIne 6 support and they won't even acknowledge that there is a problem. I have been told to find another unit online somewhere because it isn't worth fixing since its past the 90 day warranty period. Great support, huh? I wonder how many othe customers were told to toss there PODs away? Quote Link to comment Share on other sites More sharing options...
marcelgratton Posted April 13, 2019 Share Posted April 13, 2019 I have the same issue!! Brand new pocket pod buzzes as soon as it's plugged in..disappointing considering I own all line 6 products for my set up. Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 13, 2019 Share Posted April 13, 2019 Since it's brand new you should be able to return it for replacement or refund. Quote Link to comment Share on other sites More sharing options...
