bazilica20 Posted January 4, 2016 Share Posted January 4, 2016 Hi Guys just had the Helix for a few days now so apologies if this has been addressed before. Im trying to use 4 different amps in stompbox mode as the preset mode dropout issue is a problem for me.Is it possible to switch between these 4 amps?2 amps no problem, as i just assign them to one switch and toggle between the 2 of them in multiple switch mode...but 4 amps im always going to have 2 of them active at the same time surely!! Quote Link to comment Share on other sites More sharing options...
Joepeggio Posted January 4, 2016 Share Posted January 4, 2016 I think your right, its another vote for "scene" mode!! Quote Link to comment Share on other sites More sharing options...
ozbadman Posted January 4, 2016 Share Posted January 4, 2016 I don't have a HELIX, so I don't know if this is possible, but maybe this could work (you would have to be careful). Switch 1: toggles amp 1 and amp 2. Switch 2: toggles amp 2 and amp 3. Switch 3: toggles amp 3 and amp 4. Switch 4: toggles amp 4 and amp 1. So, for example, we start with amp 1 ON. Then: a) press SW1. amp1 goes off. amp2 goes on. Then: b) press SW2. amp2 goes off. amp3 goes on. Then: c) press SW3. amp3 goes off. amp4 goes on. Then: d) press SW4. amp4 goes off. amp1 goes on. and we are back to the beginning. Possible? I don't know. Useful? I also don't know. Quote Link to comment Share on other sites More sharing options...
duncann Posted January 4, 2016 Share Posted January 4, 2016 Besides the improbability of being able to run four amps with much else in the chain, it's not possible to assign a block to more than one switch. Some sort of scene switching would work. It will be interesting to see how they are going to implement this. Quote Link to comment Share on other sites More sharing options...
tagmusenmagnus1 Posted January 6, 2016 Share Posted January 6, 2016 This can be done in this way: (The link pic doesnt seem to work, but it is here: https://www.dropbox.com/s/oailz2gjmehafne/line6%204%20amps.jpg?dl=0) The Green Switch select which one of the paths to use. The Red Switch select amp in path 1 The Blues Switch selects amp in path 2 If you dont want to use three switches, you can combine the Blue and Red in one switch, but then you cant go from amp 1 to amp 4 without using two switches... If they are side by side, you might be able to hit them at the same time... Quote Link to comment Share on other sites More sharing options...
