boynigel Posted February 2, 2016 Share Posted February 2, 2016 unless i missed it in the manual, i can't seem to find a way to up the SPDIF output volume going in to protools. i have to max out the fader in pro tools that the Helix is coming in on for it to keep up w/the other tracks volume-wise. any ideas? Quote Link to comment Share on other sites More sharing options...
duncann Posted February 2, 2016 Share Posted February 2, 2016 The spdif output does seem of a lower volume than other outputs. As far as I know, there is no direct way to adjust for this. Are you using the spdif for monitoring, or recording? I use the spdif for monitoring, and record via Helix's usb, so I don't find the lower volume much of a problem. But if you're on an apple OS, the usb could currently be a problem. Have you tried making the patches you use louder? Quote Link to comment Share on other sites More sharing options...
Joepeggio Posted February 2, 2016 Share Posted February 2, 2016 I have the same problem. What i do is up the output block or you can go put a few gain blocks at end of chain for recording (stereo). I try to keep unity gain in my patches. I play a raw guitar and go from their. Too low for recording without a boost. The 1/4 and xlr are post d/a converter and have gain stages and options. I assume spdif is pre d/a so no analog staging. I dont know how hard it is to tell the digital info in realtime to be louder. I know the dsp's have the power to do it but i think the spdif is post dsp. I wouldnt want to waste dsp on spdif. I presume not as simple as a volume knob and keeping digital without converting twice. Quote Link to comment Share on other sites More sharing options...
amsdenj Posted February 3, 2016 Share Posted February 3, 2016 I find that the USB 7 direct output volumes are a little lower in output then other interfaces I have. I have to turn S-Gear's Input control all the way up for the guitar to drive the amps properly with Helix. I'm told that the USB 7 direct output is unity gain, so the low input is coming from the guitar, and isn't getting the gain provided by a typical audio interface that has input gain controls. Helix should also provide some input gain controls for direct output so that it can drive computers properly. 1 Quote Link to comment Share on other sites More sharing options...
