cbro76 Posted February 25, 2016 Share Posted February 25, 2016 Is there a way to get a clean solo boost on a good tone to go from rhythm to lead? Quote Link to comment Share on other sites More sharing options...
richardstehle Posted February 25, 2016 Share Posted February 25, 2016 I use the compressor to do this. Just give a 3 dB Boost and set the Threshold to Zero. Quote Link to comment Share on other sites More sharing options...
mcbeddall Posted February 25, 2016 Share Posted February 25, 2016 Another way is to put a jumper lead between your fx loop send and fx loop return and turn the volume up in the loop, you can assign it a foot switch to turn it on and off Quote Link to comment Share on other sites More sharing options...
urbanspaceblast Posted February 25, 2016 Share Posted February 25, 2016 Set the volume pedal at the end of the chain? Quote Link to comment Share on other sites More sharing options...
bbaron Posted February 25, 2016 Share Posted February 25, 2016 Hi McBeddal, Â What advantage do you see in your alternate solution ? Â Another way is to put a jumper lead between your fx loop send and fx loop return and turn the volume up in the loop, you can assign it a foot switch to turn it on and off Quote Link to comment Share on other sites More sharing options...
mcbeddall Posted February 25, 2016 Share Posted February 25, 2016 If your tone already uses the compressor or if you already have all your fx blocks used up it can be preferable It doesn't sound any better or anything Quote Link to comment Share on other sites More sharing options...
cbro76 Posted February 26, 2016 Author Share Posted February 26, 2016 thanks guys Quote Link to comment Share on other sites More sharing options...
cbro76 Posted February 26, 2016 Author Share Posted February 26, 2016 Which comp and how do you boost dbs? Quote Link to comment Share on other sites More sharing options...
