MichaelvanWeert Posted November 17, 2016 Share Posted November 17, 2016 Thanks for the tip! It's quite a drive from my place, but they supply a 2 year warranty on their services, that rocks! "He would have to be an authorized service center to get access to the service manual." I Googled it, found a few schematics. Not sure if those are the official technicians guides or anything of that order, but there are some hefty scheme's and algebra in them. Quote Link to comment Share on other sites More sharing options...
mirszmarsz Posted November 14, 2017 Share Posted November 14, 2017 certainly the master volume is a real pain in the neck but can be easily solved with a volume poti which is linked between the Pre amp out and Power Amp IN, basically allowing a more sensitive volume adjustment, see http://stinkfoot.se/archives/2159 I used a 100 k ohm log/Audio pot and it works great, makes the amp soo much more responsive. see also attached diagram Hope it helps! Juergen www.juka-sound-craft.eu Oh this one worked for me ... briliant idea ... First I lowered channels volume but ... Few times I almost died dialing by mistake the mode knob which reverts to higher channel volumes ... bad bad bad ! Then I experimented with extra resistor connected between wiper of Master Volume Pot and Ground but it requires opening and making changes inside the amp ... I've made it on a cable but still ... why to do it? It also reduces the highest gain unnecessary ... also bad ! Juergen proposition is most elegant and working ! Now I have an extra box with second volume pot (100k log as suggested) connected to pre-out and amp-in (send/return) permanently so my channels volume is now around 70 so the popping (while preset switching at low chan vol) issue is solved by this ! Juergen - great thanks ! Quote Link to comment Share on other sites More sharing options...
AquaRegia Posted January 16, 2018 Share Posted January 16, 2018 SV MkII with Shortboard, gigging regularly. Same issue - channel volumes saved as low as possible (any lower and I get the channel-switch pop), and yet with master volume barely on, stage volume is difficult to manage. The sound guy would say "your amp can come up a bit," and I'd tap it - couldn't even tell if it moved - and he'd say "WHOA, way too much!" Now he says "OK, I need you to BREATHE on your amp volume." LOL I'm thinking about trying the Shortboard volume pedal as a workaround. I never use it while playing - my feet are just not coordinated enough for wah (I've tried - hopeless) and the volume knob on the guitar is fine. Maybe I could physically block the volume pedal at 50% permanently...? Thoughts? Quote Link to comment Share on other sites More sharing options...
AquaRegia Posted January 23, 2018 Share Posted January 23, 2018 I answered my own question last weekend... YES for the MkI SV, but NOT the MkII. I forgot that the MkII amp/shortboard combo treats the pedal settings the same way it treats the knob positions - stored as software when you save a tone. So regardless of the physical position of the volume pedal, as soon as I click to another preset, channel volume reverts to 100%. Ouch. Got a few dirty looks during sound check for that. Now I'll have to investigate if changing ALL 40 of my saved tones' pedal preset info can do what I want, i.e., lower the volume of all 40 presets evenly. Quote Link to comment Share on other sites More sharing options...
spaceatl Posted February 14, 2018 Share Posted February 14, 2018 Just passing thru, but I thought I would mention that a few people have modified the SV Mark 2 by replacing the LINEAR master volume post with a LOG pot...LOG pots tame the ramp up...Using a LINEAR pot was a huge mistake in this amp...Another way to tame it is to jump the loop with a Buffer...an old BOSS EQ pedal can do this...You can then knock the preamp gain down and free up the Master a bit... Quote Link to comment Share on other sites More sharing options...
psarkissian Posted February 14, 2018 Share Posted February 14, 2018 With Log pots there's a risk of non-linear distortions creeping in at certain gain levels on the gain curve. So be careful and aware. Quote Link to comment Share on other sites More sharing options...
spaceatl Posted February 15, 2018 Share Posted February 15, 2018 With Log pots there's a risk of non-linear distortions creeping in at certain gain levels on the gain curve. So be careful and aware. That is hilarious! Tube amplifiers are non-linear devices... :lol: Quote Link to comment Share on other sites More sharing options...
psarkissian Posted February 15, 2018 Share Posted February 15, 2018 True,... but the processor board isn't. And need to operate tubes in the linear range of their characteristic curve, so as to not get non-linear distortions. Like with any amplifier. Quote Link to comment Share on other sites More sharing options...
spaceatl Posted February 15, 2018 Share Posted February 15, 2018 tubes are non-linear...but that is a decent conflation... :lol: The choice to use a linear pot was an enormous mistake imo...It should have been a log pot... Quote Link to comment Share on other sites More sharing options...
psarkissian Posted February 15, 2018 Share Posted February 15, 2018 Might want to discuss that with Rheinhold Bogner, since he designed the tube amp section. I forget his reasoning on that one, it was 10 years ago. Yeah, log pot is more conducive to an audio curve, makes sense, at least in an all analog tube amp. Not certain about the reasoning in a hybrid (analog/digital) amp like this. The analog tube section and the digital processor section have to to play nice with one another, and that might also be part of the reasoning behind it. Quote Link to comment Share on other sites More sharing options...
rostlaur Posted April 4, 2018 Share Posted April 4, 2018 (edited) A normal volume control has 3 pins: 1- To the source 2- The wiper to destination 3- To ground Edited April 9, 2018 by psarkissian Shock hazard on this circuit is dangerous. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted April 9, 2018 Share Posted April 9, 2018 General rule of thumb,... keep your fingers out of the insides of these amps, the shock hazard is too great. These are potentially lethal voltages if they touch the wrong thing. Even with the power off and AC un-plugged, 200V cap discharge into your hand hurts like hell. If you get a shock with both hands on the chassis, it could be lethal. Quote Link to comment Share on other sites More sharing options...
Markfothebeast Posted June 25, 2018 Share Posted June 25, 2018 On a basic amp, the current travels from one pot to the other. I did not look at my Spider Valve to see if that's how these fancy DSP units are designed. But if it is, poor (melted) solder joint(s) on just one pot can cut out volume and cause many issues. You may not be able to see the melted solder connection with the human eye. I'd personally touch up the solder joints on all of the pot legs. These amps get HOT. If you do, ensure that the nuts holding the pots to the chassis face are tight. Quote Link to comment Share on other sites More sharing options...
Markfothebeast Posted June 25, 2018 Share Posted June 25, 2018 Here's a similar issue on a bass amp with a pot. It had several symptoms from a single pot. Quote Link to comment Share on other sites More sharing options...
rlunenburg Posted May 28, 2024 Share Posted May 28, 2024 Not to bump an old topic but I have recently bought an HD100 mk1. Having the same issues that a lot of owners have, turning the master volume knob just a little bit will make it go from quiet to very loud. Using contact cleaner for this potentiometer made it a bit better but the potentiometer is not very high quality and after years of using it it has some wear, contributing to this problem. I started to remove the potentiometer in order to replace it and thats when I found the root cause of the problem. The original potentiometer is a 100k LINEAR potentiometer! In order to have a more controllable volume at lower/normal levels you need to replace this potentiometer with 100k LOGARITHMIC/audio taper potentiometer. Logarithmic pots are universally used for volume control. Since the master volume pot is directly connected to the analog circuitry of the Bogner tube amp part of the HD100 I dont understand why it originally came with a linear pot. Pure speculation from my side but this could have been an error at the factory. I have read some creative hacks in this tread but I think you are better of by replacing the master volume potentiometer with a good quality 100k log pot. And please be careful with the high voltage inside the amp, the big capacitors keep their charge for a very long time after the amp has been disconnected. You don't want to discharge them with your fingers.... Quote Link to comment Share on other sites More sharing options...
