kreator1972 Posted March 21, 2016 Share Posted March 21, 2016 anyone knows how I could set my global eq on the helix or could share some tweaking tips with using monitor speakers ?I am connected like this: JTV89 trough VDI --> Helix XLR L/R out --> Scarlett 6i6 --> M-audio av40The Frequency Response of the av40 is: 85 Hz – 20 kHz Quote Link to comment Share on other sites More sharing options...
phil_m Posted March 21, 2016 Share Posted March 21, 2016 Personally, I would recommend against using the Global EQ with studio monitors. The whole idea behind studio monitors is that they're designed to be flat, full-range, flat response reference speakers that give you a good blank slate to develop patches and/or record. They shouldn't favor one part of the frequency over the rest, so this should make it so your patches translate relatively well to different systems. If you need to make any corrections when connected to other systems, than you break out the Global EQ. If you want to use EQ as more of an effect for the tone, I'd recommend using the various EQ blocks that available as effects in the patch itself. Quote Link to comment Share on other sites More sharing options...
