billlorentzen Posted April 14, 2016 Share Posted April 14, 2016 In the manual it says active pickups for guitar and bass should be plugged into the aux input. EMG SAs are the single coil model which came out in the '80s or so, and are just slightly hotter than regular humbuckers - these are not hi gain metal pups. I just got my Helix and I'm still sussing things like this out. Anyone else using these pups and have any advice about them? I know it's about impedance, but I don't know much beyond that - I've always plugged them into regular guitar inputs. Quote Link to comment Share on other sites More sharing options...
gunpointmetal Posted April 14, 2016 Share Posted April 14, 2016 I've been plugging all my active-equipped guitars into the guitar input with the pad engaged; haven't noticed any issues. Quote Link to comment Share on other sites More sharing options...
billlorentzen Posted April 14, 2016 Author Share Posted April 14, 2016 DI, any advice? Quote Link to comment Share on other sites More sharing options...
tjontheroad Posted April 14, 2016 Share Posted April 14, 2016 In the manual it says active pickups for guitar and bass should be plugged into the aux input. EMG SAs are the single coil model which came out in the '80s or so, and are just slightly hotter than regular humbuckers - these are not hi gain metal pups. I just got my Helix and I'm still sussing things like this out. Anyone else using these pups and have any advice about them? I know it's about impedance, but I don't know much beyond that - I've always plugged them into regular guitar inputs. I have one guitar with EMG SA(X) pups. Plug it into the guitar input as normal with the auto impedance. All goodness. Quote Link to comment Share on other sites More sharing options...
nippyjun Posted April 14, 2016 Share Posted April 14, 2016 I've been plugging all my active-equipped guitars into the guitar input with the pad engaged; haven't noticed any issues. What is a pad and how do you engage it? Also. Is there any problem with plugging my passive pickup guitars into the aux? 1 Quote Link to comment Share on other sites More sharing options...
gunpointmetal Posted April 14, 2016 Share Posted April 14, 2016 In The global settings there is an input PAD option. Quote Link to comment Share on other sites More sharing options...
PeterHamm Posted April 14, 2016 Share Posted April 14, 2016 Guitar input.Turn the pad on if you need it, but only if you need it. Not everybody is reporting that it needs it. Quote Link to comment Share on other sites More sharing options...
njglover Posted April 14, 2016 Share Posted April 14, 2016 Yup, I run my Stingray bass into the normal guitar input, no problems. In fact it sounded weird in the aux (the different impedence changed the tone a bit) and I couldn't drive the SVT model as hard, so I put it right back in the guitar input. Quote Link to comment Share on other sites More sharing options...
nippyjun Posted April 14, 2016 Share Posted April 14, 2016 Also. Is there any problem with plugging my passive pickup guitars into the auxiliary input? Quote Link to comment Share on other sites More sharing options...
PeterHamm Posted April 15, 2016 Share Posted April 15, 2016 Also. Is there any problem with plugging my passive pickup guitars into the auxiliary input? Yeah, it will sound weak and shrill. Quote Link to comment Share on other sites More sharing options...
billlorentzen Posted April 15, 2016 Author Share Posted April 15, 2016 Also. Is there any problem with plugging my passive pickup guitars into the auxiliary input? With my semi hollow with passive hums, it cut highs. It was night and day - totally dull. However, my EMGs sounded fine in the aux, and didn't overdrive amps as quickly. Quote Link to comment Share on other sites More sharing options...
