FishTail Posted April 22, 2016 Share Posted April 22, 2016 I tend to use the Exp2 for Volume/Pan as a master volume when live. When I switch between patches, the volume parameter is at whatever position the patch was Saved as, NOT the actual position of the pedal. So if I heel down to take volume to 0%, and then switch to a new patch that was saved with the Volume parameter at 100%, the volume is up even though the pedal is down. This is infuriating, especially if changing out guitars on stage and you want to be sure the volume is down. Alternatively, if the patch is Saved with the volume parameter at 0%, and I switch patches mid-song with the pedal up (toe), I have to rock the pedal down and up to get the volume up. It didn't work this way with previous HD500 and PODs. Is there a way to fix this? Can you make the patch read the actual position of the pedal? Quote Link to comment Share on other sites More sharing options...
duncann Posted April 22, 2016 Share Posted April 22, 2016 There is global setting that was added in one of the firmware updates that should provide the behavior you want. Menu button -> Global Settings -> Footswitches Expression pedal position: Per preset or Global. Quote Link to comment Share on other sites More sharing options...
malhavok Posted April 23, 2016 Share Posted April 23, 2016 I just made a vid to show this off to a friend who was having trouble finding it: Quote Link to comment Share on other sites More sharing options...
FishTail Posted April 24, 2016 Author Share Posted April 24, 2016 There is global setting that was added in one of the firmware updates that should provide the behavior you want. Menu button -> Global Settings -> Footswitches Expression pedal position: Per preset or Global. Thank you! That did it. I would not have found that on my own. Felling much better :) Quote Link to comment Share on other sites More sharing options...
