srv3fender Posted April 30, 2016 Share Posted April 30, 2016 has anyone had this problem , its only halfway apparent , but if you bypass the amp its really sticks out and sounds like a acoustic electric and not like a unaltered guitar signal. Im trying to figure this out because i still partially hear the acousticiness with the amps and cabs going, i also hear it wether im plugged into a guitar amp, frfr monitors, or headphones. I want to get to the bottom of it because its annoying and i feel it takes away from being able to sound like a real tube amp. Quote Link to comment Share on other sites More sharing options...
klangmaler Posted April 30, 2016 Share Posted April 30, 2016 ...guess we need some more details of your setup to find out what 'sticks out'... Quote Link to comment Share on other sites More sharing options...
srv3fender Posted April 30, 2016 Author Share Posted April 30, 2016 american standard strat with dimarzio cruiser pickups and an air zone in the bridge Quote Link to comment Share on other sites More sharing options...
klangmaler Posted April 30, 2016 Share Posted April 30, 2016 ...that was your guitar. LOL. What about your connection(s) to (which) amp, (which) speaker... Please describe your gear... Quote Link to comment Share on other sites More sharing options...
geetar_geek79 Posted April 30, 2016 Share Posted April 30, 2016 try playing with the guitar impedance in the global setting... Quote Link to comment Share on other sites More sharing options...
srv3fender Posted May 1, 2016 Author Share Posted May 1, 2016 ok well i dont use all these similtaneously but its usually a dt25 stack, or qsc k8, or alto ts212, or akg k44 headphones, or usb into mac with altec lansing computer speakers (sounds the best with usb), using monster cables Quote Link to comment Share on other sites More sharing options...
DarrellM5 Posted May 1, 2016 Share Posted May 1, 2016 Sounds like you're passing the dry guitar signal through somewhere. I'd look at mix settings on the different blocks. Quote Link to comment Share on other sites More sharing options...
ur2funky Posted May 1, 2016 Share Posted May 1, 2016 I must say I hear this from time to time. I look down to see if I've clicked on my pseudo acoustic patch by accident. There is just a little something in the tone that says acoustic-electric. Strange. Quote Link to comment Share on other sites More sharing options...
srv3fender Posted May 2, 2016 Author Share Posted May 2, 2016 its a fresh empty patch that i build from, but you can definately here it the worst before the amp gets added when its dry, but you can still slightly hear it with the amps and effects, it does seem like the mix is 50% but there no setting for patch mix, atleast i cant find one Quote Link to comment Share on other sites More sharing options...
Tcamponovo Posted May 2, 2016 Share Posted May 2, 2016 If you have a stereo rig and try to bypass one amp, you can still hear a dry signal coming in along with your other amp sound. This is especially noticeable with a distorted amp. This MAY be what's happening. Or you could have a signal split in an awkward place in the chain. I've had similar experiences to this. Even though I bypassed one of the amps in a stereo rig, the signal is still split and going through sounding very dry. Maybe this will help. Good luck! Quote Link to comment Share on other sites More sharing options...
srv3fender Posted May 3, 2016 Author Share Posted May 3, 2016 thanks tony but its actually the dry signal that im trying to get to the bottom of because i believe if i can figure out what is coloring the dry signal (without and amps,cabs,effects, or signal splits in the chain) then i can inadvertently solve the boxiness that i can still hear with everything loaded on top of it. Can i bring it over to your house for some help, old buddy , im just in sherman Quote Link to comment Share on other sites More sharing options...
