tomatoes72 Posted May 5, 2016 Share Posted May 5, 2016 I just got the Amplifi TT and I really like it, but the Bluetooth disconnects a lot, so I need the updated firmware. When I go to download the updates, it says it is corrupt and won't go any further. I've turned off the window explorer protection thing like the page says to do before you download, but with no luck. I've tried 2 different computers with window 10 with the same results. Any ideas? Quote Link to comment Share on other sites More sharing options...
Triryche Posted May 5, 2016 Share Posted May 5, 2016 You could try flashing it with a wireless device. Depending on the current firmware you may need an iOS before gaining Android functionality. Just for clarification, you are using the Line6 Updater and it sees the TT? If so you could try running it in Win7 compatibility mode. Quote Link to comment Share on other sites More sharing options...
tomatoes72 Posted May 6, 2016 Author Share Posted May 6, 2016 I ended up using the flash method using my Ipad (though it took a couple of trys) and it seems to be working a lot better! My other issue is that when I run the Line 6 updater on my Windows 10 machine (by the way it downloads great if you use chrome and not the MS edge browser) it does not see the TT. how do I get it to recognize it? I had it connected via USB and made sure it was in my account as a registered product. Quote Link to comment Share on other sites More sharing options...
rsm0 Posted May 10, 2016 Share Posted May 10, 2016 I'm using Windows 10, the Line 6 updater sees both my FX100 and 150. To upgrade the firmware, I have to restart the AMPLIFi in update mode, however, the Updater sees my AMPLIFi. Works fine. Try this... Reboot your computer; keep the AMPLIFi off; connect the usb cable; start the updater; then turn on your AMPLIFi. Wait about 30 seconds - 1 minute; you should see it appear in the Updater list. Let us know what happens? Quote Link to comment Share on other sites More sharing options...
