Leftzilla Posted June 7, 2016 Share Posted June 7, 2016 This is off topic but perhaps someone in here may have some insight. What I am looking to do is setup an in ear monitoring system on stage that would give back Vocals, Guitars and keyboards to a small mixer that we can have permanently setup with our rehearsal mix. Okay easy enough, but I would also like to echo each input to the main board, i.e. Mike 1 send goes to both onstage mixer and mike input for main mixer board. Basically send the same signal so that each board has control over the that specific input, so that I could do individual mixes for each player onstage without affecting the main sound guy out front on his levels. Have explained the problem correctly? Would a y splitter do this job? I am just looking for a way that my band will have a dedicated monitoring system, no matter what the club setup (as long as they have a multi channel snake) Quote Link to comment Share on other sites More sharing options...
phil_m Posted June 7, 2016 Share Posted June 7, 2016 Don't know how many channels or what length you need, but sounds like this sort of thing: http://www.seismicaudiospeakers.com/16-channel-xlr-splitter-snake-cable-two-15-foot-trunks/p/SATSS-16x1515 1 Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted June 7, 2016 Share Posted June 7, 2016 This is off topic but perhaps someone in here may have some insight. What I am looking to do is setup an in ear monitoring system on stage that would give back Vocals, Guitars and keyboards to a small mixer that we can have permanently setup with our rehearsal mix. Okay easy enough, but I would also like to echo each input to the main board, i.e. Mike 1 send goes to both onstage mixer and mike input for main mixer board. Basically send the same signal so that each board has control over the that specific input, so that I could do individual mixes for each player onstage without affecting the main sound guy out front on his levels. Have explained the problem correctly? Would a y splitter do this job? I am just looking for a way that my band will have a dedicated monitoring system, no matter what the club setup (as long as they have a multi channel snake) You could potentially use the inserts on your personal mixer to send the soundman a signal but they are likely tapped after the preamp on your mixer so this is not a good idea. Some kind of XLR splitter so you can send the signal to both your board and the soundman's may be the best solution. You can buy them individually or get something like the snake or rack version below. The rack version defaults to two outputs per input but can send up to four outputs per input, ideal for instance for sending to FOH, a recording interface, and your monitor mixer. Splitter Snake http://www.seismicaudiospeakers.com/16-channel-xlr-splitter-snake-cable-two-15-foot-trunks/p/SATSS-16x1515 Rack mounted splitter with some additional functionality like ground lift and phantom power http://www.sweetwater.com/store/detail/MS8000?adpos=1t1&creative=105744828601&device=c&matchtype=b&network=g&gclid=CPr9oMfBls0CFUM8gQodvdIIrQ Single splitter http://www.amazon.com/Hosa-YXM-121-XLR3F-XLR3M-Cable/dp/B000068O59 http://www.sweetwater.com/store/detail/YMXF2XM1?adpos=1o2&creative=54989267161&device=c&matchtype=&network=g&gclid=CKvdoue-ls0CFdgQgQodE1YPAg 1 Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted June 7, 2016 Share Posted June 7, 2016 Looks like phil_m answered as I was posting, I concur. Quote Link to comment Share on other sites More sharing options...
Leftzilla Posted June 8, 2016 Author Share Posted June 8, 2016 Thanks guys I appreciate the input! Quote Link to comment Share on other sites More sharing options...
