specracer986 Posted July 25, 2016 Share Posted July 25, 2016 I bought a used JTV69 that was advertised as in mint condition. It is, except there is a problem with switching from the magnetic pickups to the modeling, that the owner didn't disclose. If I take the knob off, I can switch back and forth fine. But with the knob on, it won't switch. I almost feel that the plastic piece that protrudes down from the bottom of the knob, is too long, stopping the switch from being compressed far enough. That's just a theory at this point. I wanted to see if anyone else has had this issue before I try doing any modifying. Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted July 25, 2016 Share Posted July 25, 2016 The shaft inside the knob is too short. Cut a small piece of cardboard and shove it in there. Usually takes care of the problem. Been going on since day one...3 cheers for quality control. Quote Link to comment Share on other sites More sharing options...
CipherHost Posted July 25, 2016 Share Posted July 25, 2016 I've read others who placed something in the whole to take up a little space so the knob does not sink too low. Edit: crusinon2 beat me to it, and phrased it better too! Quote Link to comment Share on other sites More sharing options...
specracer986 Posted July 25, 2016 Author Share Posted July 25, 2016 Thanks. Sounds like my idea to shorten the plastic shaft that protrudes from the bottom of the knob would also work. Quote Link to comment Share on other sites More sharing options...
Charlie_Watt Posted July 25, 2016 Share Posted July 25, 2016 I would not modify the knob. Just put a bit of something in there to keep it from going too far on the shaft. Easy solution. Folks here have been doing that for ages because it is a common problem with the JTV. Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted July 25, 2016 Share Posted July 25, 2016 Thanks. Sounds like my idea to shorten the plastic shaft that protrudes from the bottom of the knob would also work. Perhaps, but you'll be burning a lot of extra calories to get to the same place...and you can't "undo" what you're proposing, should you f#@$ it up. A little cardboard shim is a lot less permanent and easy to adjust, if need be. Quote Link to comment Share on other sites More sharing options...
specracer986 Posted July 25, 2016 Author Share Posted July 25, 2016 I agree. If a replacement knob was available, I'd be filing the bottom of the shaft on mine, now. But without a replacement knob available, the price of failure is too high. So, cardboard it is. Just out of curiosity, if I had bought a new JTV, would it potentially have had the same problem? Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted July 25, 2016 Share Posted July 25, 2016 I agree. If a replacement knob was available, I'd be filing the bottom of the shaft on mine, now. But without a replacement knob available, the price of failure is too high. So, cardboard it is. Just out of curiosity, if I had bought a new JTV, would it potentially have had the same problem? It's a possibility. This is an old problem...and given that theses guitars tend to sit around for a while depending on where you buy it, "new" sometimes means "built 4 years ago". Quote Link to comment Share on other sites More sharing options...
