KuRiXY Posted August 24, 2016 Share Posted August 24, 2016 Damn, I should have not updated the transmitter to 1.03fw, after doing so, it will not connect to the base unless I full plug it on it before. This never happened before!!!! DO NOT UPDATE TO 1.03FW if you have a flawless working unit as I had :( Quote Link to comment Share on other sites More sharing options...
MusicLaw Posted August 30, 2016 Share Posted August 30, 2016 The firmware update solved the blinking problem with my G10 transmitter. See: http://line6.com/support/topic/22341-g10-firmware-103-fix-blinking-green-after-base-power-off/?p=171365 Sorry to hear you are having problems. You may have encountered a corrupted download or bad installation of the Updater or the firmware. Try repeating the entire procedure. Quote Link to comment Share on other sites More sharing options...
