Emik Posted October 8, 2016 Share Posted October 8, 2016 I maked a new tone, which I usually use for cabinet emulation of my Amplifi TT. This tone has no amp, only a cabinet (any type). When I set this tone to a 1st patch that is used when device turnings on (Bank 1 patch A), TT doesn't turns on. Resetting the default settings only help to fix this bug and I can use my TT then. Does anybody have this problem? PS sorry for my English! Quote Link to comment Share on other sites More sharing options...
deadlocked Posted October 9, 2016 Share Posted October 9, 2016 Have you checked posts #11 and #15 from adagosto on the thread below? There are others having issues with their own tones saved to Bank 1 Preset A. Maybe it could help leaving the default preset on B1PA and move your own preset elsewhere? If it then crashes when you switch to your own preset, then there is something within the preset that is causing the Amplifi TT to crash. http://line6.com/support/topic/12034-saving-presets-with-amplifi-tt/ Quote Link to comment Share on other sites More sharing options...
Emik Posted October 9, 2016 Author Share Posted October 9, 2016 I moved my preset to B1P2, for now it's the only way to solve this problem. I Hope it'll be fixed in the next upgrade (and changing default main volume settings too). Quote Link to comment Share on other sites More sharing options...
granetf Posted October 26, 2016 Share Posted October 26, 2016 I have exactly the same problem with my Amplifi 150 When you save an "empty" preset in A1 bank, the amp hang in "recovery mode" I don't know if this issue is known by Line6 Quote Link to comment Share on other sites More sharing options...
Triryche Posted October 26, 2016 Share Posted October 26, 2016 I would call Line6 or open a ticket, if it is a bug the more info they can gather, the more likely it will be fixed with a future FW update. Quote Link to comment Share on other sites More sharing options...
granetf Posted October 26, 2016 Share Posted October 26, 2016 @Triryche, thanks for your answer, As explained in another topic, I'm from France, so i don't think i will be really understandable at phone for this very precise issue if I call Line 6 .... (My english language is very, very poor). But I really want to help to solve this issue (i have seen some topics on the net from people who are interested for using Amplify 150 as a FRFR monitor for small gigs or at just at home, but don't need the "full power" of a firehawk 1500. it seems thats some of them will get this kind of issue with "flat & empty" preset at power ON Is there an other way to open a ticket ? Thanks, Quote Link to comment Share on other sites More sharing options...
deadlocked Posted October 26, 2016 Share Posted October 26, 2016 granetf, you can open a support ticket using the link below. I cannot guarantee that you will not have to call at some point, but it is possible that you can work through the issue using online tools. http://line6.com/support/tickets/add.html There is also an EU support line where you might be able to find someone who speaks French. The EU support team can be reached at +49 (0) 4101 303 166, Mon-Thurs 9am – 5pm CET and Fri 9am – 4pm CET. granetf, vous pouvez ouvrir un ticket de support en utilisant le lien ci-dessous. Je ne peux pas garantir que vous ne serez pas avoir à appeler à un moment donné, il est possible que l'objectif que vous pouvez travailler à travers le problème en utilisant des outils en ligne.http://line6.com/support/tickets/add.htmlIl y a aussi une ligne de soutien de l'UE où vous pourriez être en mesure de trouver quelqu'un qui parle français.L'équipe de soutien de l'UE peut être atteint au +49 (0) 4101 303 166 du lundi au jeudi 9 heures-17 heures CST et Sam 9am - 4pm. Quote Link to comment Share on other sites More sharing options...
