How to tie all 4 paths together into 1 linear path?
musiclover7
I can't seem to figure this out.  When I get 1B added as a separate path, I cannot figure out how to set the output on 1A to go to 1B.  I only see 2A, 2B, or 2A and 2B as options.  Same is true from the 2A path...  No way to select 2B as the destination.
Is there a way to daisy chain all 4 paths together in a linear fashion?
In addition to the template Peter mentioned, page 19 in the manual tells you how to set this up - lovingly referred to as "Super Serial" routing.
a2cb8c0dd481ed906e67f4042975b2fdc92e785a
