MusicLaw Posted October 18, 2016 Share Posted October 18, 2016 Finally! Now there is a USB Charging cable for the G10 Transmitter! Relay G10T USB Charging Cable See: http://www.sweetwater.com/store/detail/RelayG10TCable Quote Link to comment Share on other sites More sharing options...
a2dconverterguy Posted October 18, 2016 Share Posted October 18, 2016 I saw the necessity of that cable since I bought the spare G10-T transmitter for my G-10 set :D USB ground to G10-T Sleeve USB +5 VDC to G10-T Ring G10-T Tip = no connection seeya Joe Quote Link to comment Share on other sites More sharing options...
jws1982 Posted October 21, 2016 Share Posted October 21, 2016 +1. I actually custom made one of these a while back from a USB cable and a female 1/4" jack. A much needed part for this system. I think line6 goofed when they planned this product for just home-based use. Many guitarists, including myself, hate body-pack transmitters. I want a bug-style transmitter (the g10t is excellent), super-simple operation, and a receiver that can be powered via USB or the current pedalboard standards. The g10 system is so close to the wireless system that pretty much every guitarist I know, who doesn't tour regularly, wants. Give it more flexiblilty to power the receiver, an easy way to charge the transmitter, and slightly better range, and you've got the best selling wireless system. The bug charging is fixed with this new cable. Neither of the other two would be hard to do. Perhaps there's a version 2 in the works. Oh, and L6, if you're going with USB power, give it a standard sized B connector. Something with some meat to it. I know I'll soon be modding my g10 receiver's USB input, because it is going to fail. 1 Quote Link to comment Share on other sites More sharing options...
MusicLaw Posted November 14, 2016 Author Share Posted November 14, 2016 Just received the new G10 Relay USB Charging cable from Amazon this morning and used it to top charge my G10 Transmitter from a USB battery pack. This has already proven to be a convenient alternative charging method, as there's no need to return the Transmitter to the Base unit which is located with the amps across the room. The cable is well constructed from durable cabling and has moulded strain reliefs at both ends. The G10 Transmitter seats very securely in the 1/4" female jack. After reaching full charge (Transmitter's LED Steady Green) unplugging the cable from the battery pack causes the Transmitter (still attached to the cable), to enter Sleep Mode 4 minutes later. Leaving the transmitter connected to the cable, also will make both items far less likely to be misplaced. The cable assembly measures 44". Quote Link to comment Share on other sites More sharing options...
guitardad123 Posted July 20, 2017 Share Posted July 20, 2017 What's the charge time of the G10T with this new cable? Considering getting one, but curious if it charges as fast as the amp or receiver base Quote Link to comment Share on other sites More sharing options...
MusicLaw Posted July 21, 2017 Author Share Posted July 21, 2017 It has no degrading affect to the charge time. I have not had my G10T at minimal battery level for months, so I can't give you a time spec for a full charge using the accessory cable. On the other hand, when I'm done using my G10T after several days of use and I charge it with the accessory cable, it is fully charged in about 30 mins. Also, after having fully charged the G10ST using the accessory cable, and then did not use the G10T for several weeks, when I subsequently reconnected it to the charging cable to make sure it was brought back to fully charged status, it only took a very few minutes (about 3-5) before it was fully charged (i.e solid Green LED). Thus, the G10T's lithium battery does not loose very much of it's charge when not being used. During the several weeks of nonuse, I leave the G10T resting in the unpowered base receiver charger unit, but the G10T is NOT fully inserted in the base, and the base is not energized! If fully inserted, I believe the battery will drain in the non energized base unit. My guess is the Transmitter would go into Standby mode after 4 minutes fully inserted in the non energized base, and then it would have about 200 hours of Standby Battery life. So, to keep the Transmitter's battery in best shape, keep the Transmitter is OFF! This requires that the microswitch at the base of the Transmitter's 1/4 Sleeve is NOT depressed! Quote Link to comment Share on other sites More sharing options...
derums Posted April 3, 2024 Share Posted April 3, 2024 @jws1982 They don't offer the cable any more. can you help me to make one diy? Is all I need a usb cable and a trs connector? id appreciate any details pictures or schematics you could show me of your home made g-10t charging cable. thanks @a2dconverterguyit also looks like you made such a cable, can you give me any details? thanks guys. Quote Link to comment Share on other sites More sharing options...
abteenz Posted October 11, 2024 Share Posted October 11, 2024 I built this and it works. Ring is positive and sleeve is ground. However I believe that devices like the G10 receiver or THR30II do have some sort of other signaling going on with the transmitter while it's charging because the transmitter blinks red, orange and green while charging based on the percentage of the battery that it managed to charge. but the DIY is always green and you have to pull it on time. I guess it will reduce the life of the battery. Quote Link to comment Share on other sites More sharing options...
