grundyhome Posted October 28, 2016 Share Posted October 28, 2016 I have a Helix rack unit. I was hoping I could connect the device in to the effects loop of my amplifier. I'm currently trying this with a Peavey 6505MH and I've tried it with a Line6 DT-25 head as well. When I plug it in and setup the effects loop in the chain, I don't hear anything. Both amps didn't put out any sound. It's standard SEND --> RETURN and RETURN --> to SEND loop. I have the Helilx ports set at instrument and I'm using FX loop setting (I also tried the send/return setting as well). Has anyone else had any luck setting this up? I don't want to go through the front input as I don't like the sound I get. I know I could plug the L6 cable in to the DT-25 and that works, but I tried the effects loop just to check if the Peavey 6505MH might be bad. I was able to plug a stomp pedal in to the Peavey FX loop and it worked fine. I'm thinking the Helix signal just isn't compatible with the FX loop of the amp, but I'm not sure. Thanks in advance, SG Quote Link to comment Share on other sites More sharing options...
Thurston9 Posted October 28, 2016 Share Posted October 28, 2016 Are you plugging guitar into the Helix or the amp input? Follow up question, what input do you have selected on the Helix? Quote Link to comment Share on other sites More sharing options...
rd2rk Posted October 28, 2016 Share Posted October 28, 2016 Guitar->Helix Guitar Input Helix FX Loop (1,2,3 or 4) Send->Amp Input (where you normally plug your guitar) Amp FX Loop Send->Helix FX Loop Return (1,2,3 or 4) Helix 1/4" Mono Out->Amp FX Loop Return Put the Helix FX Loop Block (1,2,3 or 4) between the FX you want BEFORE the amp (like distortions) and the FX you want between the amp's preamp and power amp (like delays). Quote Link to comment Share on other sites More sharing options...
Thurston9 Posted October 28, 2016 Share Posted October 28, 2016 ^That. Or just go: Guitar->Helix input Helix Output->Amp Effects Return This way you only use your amps power section. Quote Link to comment Share on other sites More sharing options...
