Sometimes I can have different output levels in snapshots, sometimes not.
Rocco_Crocco
I am  trying to adjust the levels on the output block, and assign different levels for each snapshot.
I was able to do it on a patch last week without a hitch, but I tried again last night and whatever level I select for a given snapshot, that level gets assigned to ALL snapshots. WTH?? Did I inadvertently change a setting?
BTW, not sure if it matters, but this is for Glen D's boutique amp pack.
What am I doing wrong?
Make sure you have the level parameter assigned to a snapshot controller. On the Helix itself, push and turn the knob under the parameter, and brackets will appear. In the editor, you have to go to the Controller Assign tab and select "snapshot controller" from the pulldown menu. The big thing to remember is that you need to see those brackets.
Thank you that did the trick.
