joe-satriani Posted December 2, 2016 Share Posted December 2, 2016 Good evening,I have a PODXt for several years now, but the software Line6 Edit doesn't work anymore (whereas it did), as it looks for Java Runtime 1.6, whereas current Windows systems are generally equiped with Java Runtime 1.8 and upper.What do you suggest to remedy this ?Thank you in advanceRegards Quote Link to comment Share on other sites More sharing options...
Peghie Posted December 5, 2016 Share Posted December 5, 2016 Hi Joe-Satriani, I am facing the same problems. I hope you will get an answer soon. If I want to run Line 6 Edit, I got a message 'The registry refers to a nonexistent Java Runtime Environment installation or the runtime is corrupted. The system cannot find the mentioned file. I hope someone has got a solution to resolve this issue. Regards, Peghie Quote Link to comment Share on other sites More sharing options...
joe-satriani Posted December 6, 2016 Author Share Posted December 6, 2016 Exactly the same message for me. I fear that Line6 has given up this software, as the most recent version of it (Version 3.06.0) dates from august 2012 ..... I would just want them to confirm, and I hope the will propose another soft to replace it ? Quote Link to comment Share on other sites More sharing options...
Triryche Posted December 8, 2016 Share Posted December 8, 2016 Try using Gearbox. Quote Link to comment Share on other sites More sharing options...
joe-satriani Posted December 10, 2016 Author Share Posted December 10, 2016 Hi Joe-Satriani, I am facing the same problems. I hope you will get an answer soon. If I want to run Line 6 Edit, I got a message 'The registry refers to a nonexistent Java Runtime Environment installation or the runtime is corrupted. The system cannot find the mentioned file. I hope someone has got a solution to resolve this issue. Regards, Peghie Hello Peghie, according to Line6 support, there is a workaround to make Line6 Edit work under Windows 7/8 : you have to download and install a previous JRE of java 1.5 : http://line6.com/support/page/kb/_/general-faq/java-errors-with-line-6-edit-and-workbench-r538 Be careful, download exclusively the 32-bits version of it. It has worked for me. Quote Link to comment Share on other sites More sharing options...
joe-satriani Posted December 10, 2016 Author Share Posted December 10, 2016 Try using Gearbox. Thank you Triryche for your advice. What is Gearbox ? A software which allows to edit custom tones, like Line6 Edit was ? Quote Link to comment Share on other sites More sharing options...
BillBee Posted December 12, 2016 Share Posted December 12, 2016 Yep Gearbox was the next gen L6Edit. It hasn't been updated in quite a while but is newer. Quote Link to comment Share on other sites More sharing options...
