markburrows1 Posted December 16, 2016 Share Posted December 16, 2016 Hello all From my research it seems using the "Amp Out" port on the TT will only send the guitar signal to my amp/cab and not the Bluetooth to stream music. Is there another way of connecting the TT to my amp so I get everything. It would be connected to my micro terror which then connects to my unpowered cabinet. I did think about using the mains out but it seems the left hand side is not mono and I don't think a Y splitter cable from L/R output going into a effects loop port on the amp would work?? Then I also though about going from the TT's headphone port straight into my effects loop port on my amp but again not sure that would work?Any ideas at all would be much appreciated. Quote Link to comment Share on other sites More sharing options...
markburrows1 Posted December 17, 2016 Author Share Posted December 17, 2016 Anyone home :-) Quote Link to comment Share on other sites More sharing options...
ric1966 Posted December 17, 2016 Share Posted December 17, 2016 Is your unpowered cabinet full range or a guitar cab (no horn/tweeter)? Quote Link to comment Share on other sites More sharing options...
Triryche Posted December 19, 2016 Share Posted December 19, 2016 Did you test to see if the Left main is mono if you have nothing plugged into the Right main out? Quote Link to comment Share on other sites More sharing options...
markburrows1 Posted December 23, 2016 Author Share Posted December 23, 2016 Hey guys I went from the headphone port from the TT straight to the amp. The guitar sounds great and the music playback is okay but I might get some monitor speakers and put the playback to this and them the guitar to my amp if that makes sense? Quote Link to comment Share on other sites More sharing options...
usnavychiefret Posted December 24, 2016 Share Posted December 24, 2016 Microphone port? There are two "mains out" on the back of the unit (left & right). Two RCA connections to go to a home theater surround system. One "Amp Out" to go to the "guitar" input on the amp, however, only the guitars output will be present here. To get audio from another source such as iPhone/iPad/Andriod device you must route the output (mains or rca) to monitors or home stereo. You can also patch from the "Amp out" to the input on your amp (typically guitar input) to run your guitar through the amp while playing the audio from a source via the AMPLIFi app, but again only your guitar will be present at the amp. I hope this helps and isn't too confusing. There is no "microphone port" on the AMPLIFi TT. There's is a USB port and an Optical port on the rear. The USB port is for updating the firmware on the unit and the Optical out can be routed to a stereo amp that has that capability. Quote Link to comment Share on other sites More sharing options...
markburrows1 Posted December 24, 2016 Author Share Posted December 24, 2016 Apologies usnavychiefret I meant headphone port I have edited it now. It works really well from here and does everything. Only fault is backing tracks are not coming out at top notch quality but that's due to the guitar cab. But still it sounds pretty damn good! Guitar wise it's fantastic. I may use the amp out port and purchase some monitors and use the main out for audio. I am guessing the blend volume of guitar and overall audio will still work if I did this? Really liking this product so far though a lot of awesome tones! Quote Link to comment Share on other sites More sharing options...
usnavychiefret Posted December 24, 2016 Share Posted December 24, 2016 No apologies necessary Mark. I believed you meant headphone jack. I run mine through my home stereo surround system and at times I plug in one of my amps to go along with the audio on the stereo. I also have a Line 6 FBV Shortboard Mk II that I use with it. I haven't figured out all the nuances of the Shortboard yet but will be working with that this next year. Merry Christmas! Quote Link to comment Share on other sites More sharing options...
