litesnsirens Posted May 3, 2013 Share Posted May 3, 2013 So those Fly mount screws could serve another purpose. I'm working on a project now to see if it will work. I bought a couple of these from Long and McQuade up here in Canada. I don't think the holes will line up but I'll just drill some holes if I have to to line up with the fly mount screws. But once I have that done, I'll cut some very short speaker/light pole so that I can set up my lights on top of the L3t's. These are the lights I have, I have 2 of these and these 4 little lights are really powerful and really lightweight and can easily light up the stage. I'm hoping this will work out nicely but I thought I would share in case others want to try or if Line 6 wants to look into making something that fits perfectly. Quote Link to comment Share on other sites More sharing options...
dboomer Posted May 3, 2013 Share Posted May 3, 2013 The issue is tipping safety. In order to get certification for putting speakers up on a pole they have to be stable to a specified amount of tip angle and be able to recover if tipped that far. Our speakers are as high up as can be certified. If you add weight or height to the tops they would no longer be able to be certified and could fall over (hopefully not on a customer) if a drunk falls into them. So I have to say that it's not a safe practice and advise against doing it. Quote Link to comment Share on other sites More sharing options...
litesnsirens Posted May 3, 2013 Author Share Posted May 3, 2013 I get what you're saying, but essentially when I cut the pole, it will just be to hold the lights in place. I want them to be basically resting on the top of the speaker but with the pole inserted for security. It's hard to tell from the picture but those lights are really light and small. It's 21" wide and maybe 8 lbs. So the additional weight etc. wouldn't be significant. But that's MY lights and MY circumstance so I can see how you wouldn't promote such use as a general practice. Given that you're saying these speakers are barely within certification, adding heavier lights, raised up higher than the speaker and wider could seriously compromise safety. These lights will overhang past the speakers 4" on either side less if they are corner to corner which is the most likely scenario. With the speakers facing directly forward, I would likely have the lights on a 45 degree angle back towards the stage. In MY situation I think that if a drunk were able to knock over the speaker with MY lights on top, the speaker would be going down anyway. I do appreciate the input though I will be vigil in setup and watching over to try to minimize the risk. Quote Link to comment Share on other sites More sharing options...
litesnsirens Posted May 4, 2013 Author Share Posted May 4, 2013 Here is the final product, it's going to work perfectly. I just wanted to show the scale of how small these LED lights are. They were pretty damn expensive but they throw a lot of light for such a small package. 2 Quote Link to comment Share on other sites More sharing options...
schrismer Posted May 16, 2013 Share Posted May 16, 2013 Hey Gear Head.... could you send me the model number for those lights and the mounting thing..lol... schrismer@drakecomfort.com thanks, Steve Great Idea btw!!!! Quote Link to comment Share on other sites More sharing options...
litesnsirens Posted May 16, 2013 Author Share Posted May 16, 2013 I got both items from Long and McQuade so I am giving you the info from the Long and McQuade website. The pole mount adaptors are; Yorkville Sound Speaker Stand External Mount SKS-ADAPT Price: $6.99 The lights are; Yorkville Sound LP Series Dimmer Bar w/2 LED Heads LP-LED2 Price: $855.00 1 Quote Link to comment Share on other sites More sharing options...
schrismer Posted May 17, 2013 Share Posted May 17, 2013 THanks!!!! Quote Link to comment Share on other sites More sharing options...
litesnsirens Posted May 17, 2013 Author Share Posted May 17, 2013 no problem. You'll then just have to cut down some speaker pole to the size you want. I cut some really short ones. But I may cut a couple of longet pieces in case I just stack the L3t right on top of the L3s. Quote Link to comment Share on other sites More sharing options...
litesnsirens Posted September 9, 2013 Author Share Posted September 9, 2013 I didn't necessarily want to bring this back to the forefront but I have been doing this for quite a few gigs now and since I have both long and short Line 6 threaded speaker poles I have found that I have great flexibility. I want to go on record as saying that I heed dBoomers advice re: tipping but with these small LEDs it really isn't an issue any more than the speakers themselves. I wouldn't try this with wider heavier lighting trees. In my last post I stated that you would need to cut down some speaker/light poles but at the time of that post I didn't have the short Line 6 poles. Now I have the option of mounting the L3t's on the short poles on top of the L3s's and using the long Line 6 poles for the lights or vice versa, mount the L3t's on the long Line 6 poles and use the short ones for the lights. I don't have to use the cut down lighting poles at all anymore. I will endeavour to take some pics of each variation over the next coming gigs so you can see how the set up looks in either configuration. Quote Link to comment Share on other sites More sharing options...
Digital-sound Posted September 10, 2013 Share Posted September 10, 2013 I like that idea and did the same with my ef500p's over my ls801p's. I then actually put two more pole mounts in my subs so I could just put the lights on a pole into the subs. I think for the smaller stages, it is a great way to save space and speed up set up. I am g As to see it works on the L3t's too. I don't really want to drill a hole in the L3s for a light pole.....but never know..I might. Glad to see some pictures. Thanks litesnsirens. Quote Link to comment Share on other sites More sharing options...
Digital-sound Posted September 10, 2013 Share Posted September 10, 2013 How did the holes on the to of the speaker line up with the holes of the pole mount? Quote Link to comment Share on other sites More sharing options...
litesnsirens Posted September 10, 2013 Author Share Posted September 10, 2013 They lined up perfectly, I just undid two of the flymount screws, put the pole mount in place and then screwed the flymount screws back in. Totally reversible with no damage to the L3t at all. Quote Link to comment Share on other sites More sharing options...
litesnsirens Posted September 10, 2013 Author Share Posted September 10, 2013 Actually, now that I think of it I may have had to modify the pole mount a bit but it was easy and again as long as it doesn't affect the L3t. Quote Link to comment Share on other sites More sharing options...
Digital-sound Posted September 10, 2013 Share Posted September 10, 2013 Yes, it beats drilling another pole mount in the sub. Quote Link to comment Share on other sites More sharing options...
