rccampeon Posted January 2, 2017 Share Posted January 2, 2017 HELP!!! Guys I need your help. I just got my Helix an hour ago. I turned it on, it booted OK, it came with firmware version 1.03. Went to the line 6 site, followed the instructions for updating to the latest firmware 2.11. The update failed, now everytime I turn on the Helix I get a message that says "Boot failure. Entered Update Mode!" and I see a red ":0" at the top left side of the Helix screen. I have tried to turn it off and press F6 and F12 together and turn it on again but I get the same error "Boot Failure. Entered Update Mode!". I'm going crazy here, I haven't even use it yet, I can't believe this is happening, I really need your help here. I also tried to update the firmware manually by downloading the firmware file from line 6 site and then started the Line 6 Updater in offline mode, but the update keeps failing. I have Windows 10, I don't have another PC to try it. I tryied also chaging the USB port as I read somewhere that a user fixed it doing this, but in my case, it didn't help Any ideas? Thanks a lot 1 Quote Link to comment Share on other sites More sharing options...
spikey Posted January 2, 2017 Share Posted January 2, 2017 Just guessing- Did you try reinstalling the software? Turn it on. Let it say boot failure. Then see if it will let you reinstall the software via Line 6 updater. 1 Quote Link to comment Share on other sites More sharing options...
rccampeon Posted January 2, 2017 Author Share Posted January 2, 2017 It is solved. I changed from a front USB port to a USB port in the back of the PC and the firnware was updated sucessfully, and the Helix came back to life!!!! Thanks 1 Quote Link to comment Share on other sites More sharing options...
zooey Posted January 3, 2017 Share Posted January 3, 2017 Same thing happened to me. Only one USB port works reliably for Helix, where there others work fine for everything else. Weird, but sorted. Quote Link to comment Share on other sites More sharing options...
rugas Posted April 30, 2017 Share Posted April 30, 2017 In the update to v2.21 I get boot failure. If I press f6 & f12, it shows me "Entered Update Mode!"Line6 Updater is in version 1.11. The software does not recognize my helix and I can do nothing from the MacBook.What now? 1 Quote Link to comment Share on other sites More sharing options...
wrobinette Posted August 15, 2017 Share Posted August 15, 2017 I am having the same issue. Tried to update firmware and it failed. 1 Quote Link to comment Share on other sites More sharing options...
Ashgrunwald Posted October 27, 2017 Share Posted October 27, 2017 I am having the same issue. Tried to update firmware and it failed. Me too!!!! It was half working for a while with the sound cutting out every now and again. Now I'm stuck on the old 'Boot failure'. I'm going out of my mind as well!!!!!. I'm a pro muso and have to use the Helix for some festivals. Such a lollipoping shame. I was digging it until I updated it. Quote Link to comment Share on other sites More sharing options...
hideout Posted October 30, 2017 Share Posted October 30, 2017 You know what, if Line 6 does nothing else in the next update, if they could just fix this nerve wracking process, I think we’d all be thankful. 1 Quote Link to comment Share on other sites More sharing options...
LBET Posted November 26, 2017 Share Posted November 26, 2017 Add one more name to the list. Mid 2012 13 MacBook Pro. I'm trying to upgrade 2.21 to 2.30. First problem was with the backup because I had the problem where the USB connection was lost. Solved that one by following the instructions and shutting down everything that might want to say hello to to USB audio. When the backup finished and I used the updater app I got an unsuccessful update and I'm stuck in "Enter Update Mode". I really hoped they would have provided some guidance on the nature of the mythical mode and how to get get there from the 3rd di-flippin-mention. Keep you posted. Quote Link to comment Share on other sites More sharing options...
jeremyn Posted November 26, 2017 Share Posted November 26, 2017 See this thread: http://line6.com/support/topic/30581-helix-230-firmware-failure-boot-failure-entered-update-mode Quote Link to comment Share on other sites More sharing options...
jcharter Posted November 30, 2017 Share Posted November 30, 2017 i did the same thing..... i switch to the back USB instead of the front and mine updated..... i think it has to do with USB speed and version Quote Link to comment Share on other sites More sharing options...
maurizioviera Posted July 13, 2018 Share Posted July 13, 2018 Yes, switching the USB port works! Quote Link to comment Share on other sites More sharing options...
SeanVoyce Posted June 3, 2020 Share Posted June 3, 2020 Tried all USB ports on 3 laptops (all I have) - no success ;-( 1 Quote Link to comment Share on other sites More sharing options...
StratzelBack Posted May 11, 2021 Share Posted May 11, 2021 I have the same issue. People say that connecting a different USB cable to the unit or changing the USB port on my laptop will make it work. I have tried all of these and that doesn't help. It was talking to the unit fine before so I don't think it is the USB cable. I need to get the unit back up and factory reset doesn't even work. How do I fix this? My Helix is a brick until the firmware update is successful. My computer rebooted in the middle of the firmware update process and that is what initially caused the problem. Quote Link to comment Share on other sites More sharing options...
