hgmort Posted January 20, 2017 Share Posted January 20, 2017 I have a question about the master volume for my HD 500x? If I get the volume I want when switching between presets will the master volume turn all of those up and does it have to be saved if it does. The problem is for some reason when playing through out board and trying to record a live show my channel is a bit fuzzy when the other guitarist is not and all the settings are the same on the board? Quote Link to comment Share on other sites More sharing options...
silverhead Posted January 20, 2017 Share Posted January 20, 2017 Yes, the Master volume will affect the volume level of all presets. No it does not need to (and cannot) be saved. Try increasing your individual preset volume levels while maintaining their relative levels to each other (a manual and time consuming task but necessary if you have never done it), then decreasing your Master volume level until the fuzziness disappears, and increasing the HD500X channel level on your board as required to balance with the level of your other guitarist. Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted January 20, 2017 Share Posted January 20, 2017 Master volume, is a completely standalone volume. It does not get saved to the patches. Set your master volume once, and then use volume controls that are within the patches to create an equal level between patches. Master Volume and Global EQ are two things that stand outside of patches and can ruin or improve your overall experience. Quote Link to comment Share on other sites More sharing options...
hgmort Posted January 20, 2017 Author Share Posted January 20, 2017 Ok Sounds good thanks! That for sure sounds like a big task since I have 4 presets. Thanks again! Quote Link to comment Share on other sites More sharing options...
