Oxygen87 Posted February 20, 2017 Share Posted February 20, 2017 Hey, I've been experiencing a drastic volume changes while I'm switching between patches. (video at the end in case i won't make myself clear) Let say I play with patch X then i switch to patch Y the volume changes sometimes too low and sometimes too high and as soon as I turn the volume knob a little bit the volume returns to its original setting. It's a pain in the lollipop while i'm playing with my friends and I don't know what to do. Should i just reset my device or is it a common issue with the HD series ? Thanks buddies. **I was holding the camera in one hand so I couldn't play nothing :)** Quote Link to comment Share on other sites More sharing options...
BillBee Posted February 20, 2017 Share Posted February 20, 2017 Try parking the knobs at 0. That usually stops it. Sometimes knob jitter can be cleared up by spinning them one way and then the other way (unit off of course). Quote Link to comment Share on other sites More sharing options...
Smashcraaft Posted February 20, 2017 Share Posted February 20, 2017 Try parking the knobs at 0. That usually stops it. This and not being connected to HD Edit via USB. Quote Link to comment Share on other sites More sharing options...
Oxygen87 Posted February 20, 2017 Author Share Posted February 20, 2017 I've tried to turn them like crazy (all the knobs especially the volume one) in case something got stuck there, but no luck. and it happens also when i'm not connect VIA USB. Quote Link to comment Share on other sites More sharing options...
Oxygen87 Posted February 21, 2017 Author Share Posted February 21, 2017 Update: I reset my HD500x (I've re-flashed with Line 6 Monkey), but there was no luck. also, it looks like the presents have been reset and what I want is TOTAL FACTORY RESET (setting,amps etc...) how can i perform it ? is there any other way ? i'm seriously considering to buy another unit, outside the Line 6 family. (i'm a little bit disappointed with this issue) thanks ! Quote Link to comment Share on other sites More sharing options...
BillBee Posted February 21, 2017 Share Posted February 21, 2017 A reflash is a total reset AFAIK. Try parking the knobs that seems to work for many who have this problem. Quote Link to comment Share on other sites More sharing options...
Oxygen87 Posted February 21, 2017 Author Share Posted February 21, 2017 Hey Bill, By parking you mean pull off the knob play with it a little bit and then put it back in? I probably didn't understand you fully. Quote Link to comment Share on other sites More sharing options...
BillBee Posted February 21, 2017 Share Posted February 21, 2017 Turn all the knobs to 0. When you start the HD it will default to what the preset settings are and should ignore the physical knob settings. Hope that works. Quote Link to comment Share on other sites More sharing options...
Oxygen87 Posted February 21, 2017 Author Share Posted February 21, 2017 Thanks buddy, Just did it, didn't work... One more thing, I dont want it to ignore the physical knobs setting, the opposite. I want every present i switch to, to embrace the physical knobs setting. and it manages to work, only when i turn the volume knob a little bit as you see in the video. for example if i'll switch between patches while the volume knob turn to 1, then patch will be louder then that. Quote Link to comment Share on other sites More sharing options...
BillBee Posted February 21, 2017 Share Posted February 21, 2017 Its not a matter of ignoring the knobs its just a test to see what is going on. It could be a bad cable for example. But when a patch is recalled it will be at whatever settings it was programmed for not where the knobs are at. When you move a knob then the setting will jump to the position. Quote Link to comment Share on other sites More sharing options...
napynap Posted February 22, 2017 Share Posted February 22, 2017 Could it be a bad active pickup battery? Have you tried a different guitar? Quote Link to comment Share on other sites More sharing options...
