thomasr97 Posted March 1, 2017 Share Posted March 1, 2017 Variax JTV 59. One custom Alt Tuning made and loaded via WorkBench HD. When I play, I often change tunings on the fly (between songs). This has worked beautifully for me for over 2 years now. The other day, they Alt Tunings became scrambled and now Standard is under another setting, that setting is gone and others seemed messed-up. 1) Any ideas on how it happened (all other features seem to work fine)? 2) How do I recover? TIA :D Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted March 1, 2017 Share Posted March 1, 2017 Best you can hope for is that re-flashing the firmware will undo whatever chaos the universe has wrought...it'll ask you if you want to keep the presets currently on the guitar. Say "yes" unless you want to start from scratch with whatever adjustments you've made in Workbench. 1 Quote Link to comment Share on other sites More sharing options...
thomasr97 Posted March 1, 2017 Author Share Posted March 1, 2017 Update:Thanks, Guru, I did that already - no change.Also, I just pushed the entire .BUN file that I saved right after I made this set-up - no change. My next step: factory reset, test. If OK, re-push the .BUN and test again. Quote Link to comment Share on other sites More sharing options...
thomasr97 Posted March 2, 2017 Author Share Posted March 2, 2017 Ok, so the full-on hard reset (including the button-smash hard reset of Alt Tunings) solved the problem. Thanks for helpibng :) Quote Link to comment Share on other sites More sharing options...
