Hearing Pod Farm 2.5 Platinum Output but not able to record it?
Okay I'm having a problem.
I own Pod Farm stand alone platinum, and I am using a Focusrite Scarlett 2i2 interface.
My mic (sE Electronics sE2200a II C) is plugged directly into my 2i2, which is plugged into my PC via USB. I have my headphones plugged in via the headphone Jack on the front of the 2i2.
In pod farm I have my preferences set as Focusrite USB ASIO and I can hear my applied effects in real time.
However I can't record my output with those effects!
How do I do this?
I really want to use this for streaming (OBS) and I know its possible but I have no idea how!
What do I have to do?
Do I need Virtual Audio Cable or anything?
When I record or stream it only records the direct input before the effects!
Depending on your DAW and computer hardware, you could also just use the Focusrite direct to your DAW (do not open PF Standalone) and apply the PF plug-in to your track.
This sort of makes sense, I am using Adobe Audition but I will use whatever I have to, to stream the pod farm output to the DAW.
Would I be able to do this if I changed to Pro Tools | First & Ableton Live Lite recording software that came with the scarlett 2i2?
I did some reasearch and it looks like Adobe Audition isn't compatible.
So if i switch to Pro Tools First or Ableton Live lite would I be able to stream this to OBS with the pod farm output?
