staypuff54 Posted March 18, 2017 Share Posted March 18, 2017 Hi, Loving my helix so far, but I just started having a funky issue with the volume pedal block. When I start to roll it forward I hear guitar volume, but as soon as the pedal stops moving or comes close to 100% the volume shuts off. I plugged in an external expression pedal and tried it and had the same problem. Any help would be appreciated! Quote Link to comment Share on other sites More sharing options...
jbuhajla Posted March 18, 2017 Share Posted March 18, 2017 Does the percentage of the volume block drop to 1% when it shuts off? What firmware are you on? Quote Link to comment Share on other sites More sharing options...
Joepeggio Posted March 18, 2017 Share Posted March 18, 2017 Exp 1? Or exp 2? Getting at the exp 1 volume bug. Supposed ti be addressed soon. Hopefully Quote Link to comment Share on other sites More sharing options...
staypuff54 Posted March 18, 2017 Author Share Posted March 18, 2017 It happens whether I'm on EXP 1 or 2, and it goes all the way down to 0%. I'm on 2.12 Quote Link to comment Share on other sites More sharing options...
biggarfish Posted March 19, 2017 Share Posted March 19, 2017 I'm having a similar problem but I think slightly different. I use Exp 2 for Volume only and Exp 1 for Wah, effects etc. When I had the HD500 my Exp 2 Roland EV5 worked fine but with Helix it works in the opposite direction, all the way forward is Min 0% and back is Max 100% and I don't like that. I've tried to reset it manually but can't figure out what I'm not doing correctly to fix this. Any thoughts out there on what I need to do to remedy this? Thanks Chris Quote Link to comment Share on other sites More sharing options...
spikey Posted March 19, 2017 Share Posted March 19, 2017 When I had the HD500 my Exp 2 Roland EV5 worked fine but with Helix it works in the opposite direction, all the way forward is Min 0% and back is Max 100% and I don't like that. I've tried to reset it manually but can't figure out what I'm not doing correctly to fix this. Have you tried swapping the tip with the sleeve wires in the EV5? That might work. Quote Link to comment Share on other sites More sharing options...
jbuhajla Posted March 20, 2017 Share Posted March 20, 2017 Make sure your volume blocks are assigned to EXP2, and if you are using wah, assign it to EXP1. There is a bug when assigning volume to EXP1, the volume % will randomly drop to 0-1%. Quote Link to comment Share on other sites More sharing options...
