Bangha Posted March 28, 2017 Share Posted March 28, 2017 H everyone, I'm wondering, is there any way to increase the output of the USB7 out? I'm currently recording my album, and am recording dry tracks for safety should I choose to reamp in the future, their output however is rather weak and I'd much rather record a bit hotter to improve my signal to noise ratio. Thanks Quote Link to comment Share on other sites More sharing options...
PeterHamm Posted March 28, 2017 Share Posted March 28, 2017 Pretty sure you can not. It's just a pass thru from the get input. Quote Link to comment Share on other sites More sharing options...
phil_m Posted March 28, 2017 Share Posted March 28, 2017 You can increase the gain inside the DAW any number of ways. You don't want to, though. The dry signal is the signal directly from your guitar, which is quite low. You want to keep it like that for re-amping purposes because when you send it back to the Helix it will be correct for being sent back through the Helix's signal path. So don't mess with it. 1 Quote Link to comment Share on other sites More sharing options...
PeterHamm Posted March 28, 2017 Share Posted March 28, 2017 You can increase the gain inside the DAW any number of ways. You don't want to, though. The dry signal is the signal directly from your guitar, which is quite low. You want to keep it like that for re-amping purposes because when you send it back to the Helix it will be correct for being sent back through the Helix's signal path. So don't mess with it. Yup. This, too. Quote Link to comment Share on other sites More sharing options...
