jimbomcmucka Posted March 31, 2017 Share Posted March 31, 2017 Hi guys, I have always used a very simple rig, guitar, few analogue pedals, valve amp. But have recently joined a band that requires a bit more versatility in my tone. So, I purchased a Hd500x. I have been playing around with the amp modeling etc and am really impressed. But have found playing the Hd500x straight into the PA a little limiting. Usually the venues have poor monitoring so am playing blind. I decided to experiment using the HD to add effects and change channels of my amp. So, I purchased a G Lab mac 4.4 to act as a Midi interface between the HD and the amp. I watched videos online of products like the amp gizmo etc and this seemed like a good budget alternative. However I am now completely confused! Has anybody out there tried this with any success? If so, would you be able to give me a simplified step by step? The manual for the GLab is here: http://www.glab.com.pl/download/um_mac_14062011.pdf&ved=0ahUKEwizmcrzuYHTAhVJGsAKHbOWBwEQFggaMAA&usg=AFQjCNEEbgOJQ_i5B4TPPo9sRFZ2rnMq1A&sig2=Bxbd_TG2ElCCLiecEEdLEg I'm using a Fender Blues deluxe amp, which just uses a stereo footswitch, one button for channel select and one for reverb on/off. Any help is greatly appreciated! Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted March 31, 2017 Share Posted March 31, 2017 Here's a better solution ---- Go direct. When you find a place with sub-par monitoring, use your amp as the monitor. Quote Link to comment Share on other sites More sharing options...
jimbomcmucka Posted April 1, 2017 Author Share Posted April 1, 2017 Good point. But I do also really love the tones of my amp, so for some situations would still like to use it. Quote Link to comment Share on other sites More sharing options...
spaceatl Posted April 1, 2017 Share Posted April 1, 2017 Might be worth adding things up...If you traded on a Helix, you get built-in control relays and an HD on steroids....just a thought. Quote Link to comment Share on other sites More sharing options...
