Sign in to follow this
Guest Clanton man
Volume Levels
Guest Clanton man
I have the app to edit tones but it shows a minimum volume level and a maximum volume level? I would like to have all clean tones slightly lower than any distorted or lead tones that I want to use for the purpose of playing live. Is there a simple way to do adjust this?
I'm noticing on some of the tones that I add from the "cloud" are very loud in comparison to others.
Adjust the level in each patch with the amp model's volume knob.  Make sure to save after each adjustment or else your changes will be lost when switching to a different patch.
After you got your clean and dirty tones at the level you want them, adjust the overall volume using the Master volume on the front of the amp.
The levels on tones from the cloud are always going to be different because they were created by different users.  Different guitars and a user's experience on how to create a proper patch is also a factor.
