DanielJW Posted April 25, 2017 Share Posted April 25, 2017 I've been using the G10 a lot recently and the only issue I have is the USB power supply. I was thinking how much more practical it would if it could be powered from your pedalboard power supply eg 9v adapter to G10 charger. Does anyone know if an adapter like this exists and what it would be called? Or if I'd be able to get one built at an electronics store or something like that? Thanks Quote Link to comment Share on other sites More sharing options...
Lee7uk Posted April 25, 2017 Share Posted April 25, 2017 Hi, I encountered that same problem, so I had my tech make this mod for me so I can have my base unit powered from my 9v supply from my Boss BCB board. Small 9v to 5v step down convertor that sits just nicely in the recess were the cables go. http://line6.com/support/topic/21552-how-to-power-g10-from-a-standard-pedal-board/ Quote Link to comment Share on other sites More sharing options...
talonmm Posted April 26, 2017 Share Posted April 26, 2017 I've been using the G10 a lot recently and the only issue I have is the USB power supply. I was thinking how much more practical it would if it could be powered from your pedalboard power supply eg 9v adapter to G10 charger. Does anyone know if an adapter like this exists and what it would be called? Or if I'd be able to get one built at an electronics store or something like that? Thanks there is a design flaw with the way the female power jack inside the unit is attached to the main board. many users of the g10 have complained about how their jack broke during routine use. there are 1 - 2 semi-active subjects in this forum section that have dealt with a better long term solution and how to modify the unit internally to accommodate a better power solution that will not break as easily as the original design. Check them out and see if they are a better fit for your situation and perhaps you may not want to wait until your system breaks as so many of us have experienced. Quote Link to comment Share on other sites More sharing options...
Lee7uk Posted April 26, 2017 Share Posted April 26, 2017 there is a design flaw with the way the female power jack inside the unit is attached to the main board. many users of the g10 have complained about how their jack broke during routine use. there are 1 - 2 semi-active subjects in this forum section that have dealt with a better long term solution and how to modify the unit internally to accommodate a better power solution that will not break as easily as the original design. Check them out and see if they are a better fit for your situation and perhaps you may not want to wait until your system breaks as so many of us have experienced. But if the base unit is permanently fixed in one location there shouldn't be any need to modify the poor USB input on the G10, mine has been in my board since purchasing upon release in the UK without any problems. Even my other one that is used for bass was bought at the same time and that has done a lot of gigs and is packed away after every show. Although I do envisage the USB input to fail, so far so good. Quote Link to comment Share on other sites More sharing options...
talonmm Posted April 26, 2017 Share Posted April 26, 2017 I have three g10's, and one broke so I had the mod done on all three. The one that broke, was also attached on a peddleboard but that did not prevent it from breaking. The input jack faced the outside edge of the peddleboard so the wire often was off the board. It got lightly pushed and the pushing pressure sent to the power-jack was enough to loosen it and make it no longer work. Since doing the modification, I now have turned the unit so the guitar output and power source no longer face the edge of the peddleboard. If you are gigging with one or both units it's only a matter of time before something silly happens and you lose the unit. Quote Link to comment Share on other sites More sharing options...
chrisjnyc Posted January 18, 2018 Share Posted January 18, 2018 Would anyone want to mod my G10 for $40? Quote Link to comment Share on other sites More sharing options...
Sorg Posted January 24, 2018 Share Posted January 24, 2018 Could anyone post a picture of what kind of modification they have done to their unit? Is this only a problem with the G10 or also with the G30 and G50? 1 Quote Link to comment Share on other sites More sharing options...
JerryWawak Posted January 25, 2018 Share Posted January 25, 2018 I just had to submit a warranty claim on mine because the female jack is loose and won't keep a constant connection. It failed on me mid song last Sunday. You have to wiggle the wire to get it to connect and then it looses connection randomly. Needs a much more robust connection than a mini USB. Quote Link to comment Share on other sites More sharing options...
Tmack5 Posted April 18, 2018 Share Posted April 18, 2018 If you warranty is up or you don't mind losing it you can try this mod which works well for me. I have a 0ne Spot power supply with 8 barrel connectors. I think the barrel connectors come in 3,5 or 8. I ordered a micro usb to dc converter from amazon. Cut the last barrel connector line and reverse the polarity black to red, red to black. solder wires and wrap with shrink wrap or electrical tape. Plug into the g10. attached is a picture. remember you will definitely void your warranty but it works. Attached is a pic of the part. Quote Link to comment Share on other sites More sharing options...
letsrig Posted December 13, 2018 Share Posted December 13, 2018 I had the same concern so I made up some power converters that allow me to power it from my 9V power supply on my board. I made up a bunch of these to sell so if you want one, let me know. I have mine mounted in an Altoids tin that sticks to my pedalboard with Velcro. Works like a champ! Quote Link to comment Share on other sites More sharing options...
kijuer Posted December 15, 2018 Share Posted December 15, 2018 Me wants one!!!! Where do you live? I need to have one sent to Italy...if it's not too expensive :-/ Quote Link to comment Share on other sites More sharing options...
Scooter127 Posted December 21, 2018 Share Posted December 21, 2018 Quote Link to comment Share on other sites More sharing options...
