Anteater74 Posted May 10, 2017 Share Posted May 10, 2017 Hi I'm thinking of getting an amplifi 30 but need some questions answered if poss. Will my ipod 6 work with this? Can i use my Helix through this...and how will it work? Thanks Quote Link to comment Share on other sites More sharing options...
Triryche Posted May 10, 2017 Share Posted May 10, 2017 Yes your iPod 6 will work with it. You could run the output of the Helix into the AMPLIFi, (best option the Aux In), however there would be no further integration. Quote Link to comment Share on other sites More sharing options...
cloph Posted May 11, 2017 Share Posted May 11, 2017 FYI: you posted in the non-speaker variant section (the TT (table top) or FX floorboard subforum) - but to clarify things a lot more:Why do you want the Amplifi 30 if you already got a helix that has superior functionality in terms of modeling? Just to have a speaker? Why not hook up to a home stereo? Why not a powerstage and a PA/frfr-speaker (or active speaker for that matter) or a classic guitar cab? I mean owning a helix and then going through the smallest amplifi sounds a little pointless to me, only satisfying the play-in-your-livingroom szenario (where you likely could just hook it up to your home stereo) - so I kind of expected combination with a gigable version, something that can compete with a drummer/other bandmembers. So it is not really a question whether you can hook up the helix to the Amplifi (yes you can, you could either hook it up via the Aux In as mentioned for using it as a mere speaker, or use the guitar input in combination with the fx-loop out on the helix if you want to add some additional processing in the amplifi). The question is: does that make sense for whatever is your end-goal? Quote Link to comment Share on other sites More sharing options...
