sequenzer111 Posted May 19, 2017 Share Posted May 19, 2017 Hi guys, I hope you can help me. How I can create two different blocks togsthsr on one nob. I would like to play a Booster and a Delay at same time and one step on the knob. I hope you can help me step by step. Thank you! Quote Link to comment Share on other sites More sharing options...
migueledge Posted May 19, 2017 Share Posted May 19, 2017 It´s so easy. You can do it in differents ways, i prefer with snapshots, you can turn on/off a lot of blocks with only one switch. Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 19, 2017 Share Posted May 19, 2017 - use the joystick to select the Boostr FX block - using your finger, touch (don't press) the desired footswitch - when the screen display changes select CONFIRM - select the Delay FX block - touch the same footswitch. Select the Merge (not Replace) parameter then select Confirm again. Quote Link to comment Share on other sites More sharing options...
Verne-Bunsen Posted May 19, 2017 Share Posted May 19, 2017 This is covered in detail on page 40 of the manual. It's worth reading as there is quite a lot of helpful information in it. You'll probably find answers to a lot of your questions. http://line6.com/data/6/0a06439c975d5787c3e351aa0/application/pdf/Helix%202.0%20Owners%20Manual%20-%20Rev%20D%20-%20English%20.pdf Quote Link to comment Share on other sites More sharing options...
sequenzer111 Posted May 19, 2017 Author Share Posted May 19, 2017 Thank you some much guys for youre help. It works and I´m happy. :-) Best regards. Damian Quote Link to comment Share on other sites More sharing options...
