twystedriffs Posted June 9, 2017 Share Posted June 9, 2017 So I have a jam man, hadnt used it with helix, figured just assign it to a send, but doesnt seem to be getting any signal working. Any one?? Thanks! Quote Link to comment Share on other sites More sharing options...
PeterHamm Posted June 9, 2017 Share Posted June 9, 2017 You have to set the send up in your patch in Helix otherwise no audio is going to it. Quote Link to comment Share on other sites More sharing options...
twystedriffs Posted June 9, 2017 Author Share Posted June 9, 2017 Well, I have send and return cables to the jam man, and put in a send block, it is on.. what am i missing? Quote Link to comment Share on other sites More sharing options...
MusicLaw Posted June 9, 2017 Share Posted June 9, 2017 Recheck your patch cables are in the correct jacks. Others have had that problem. Also check the level settings in the FX Loop Block, or in the Send Block and Return Block if you went that route. And, make sure that the Blocks are not Bypassed in the Helix Signal Path. Otherwise, check your cables to confirm they're good. Quote Link to comment Share on other sites More sharing options...
PeterHamm Posted June 10, 2017 Share Posted June 10, 2017 Well, I have send and return cables to the jam man, and put in a send block, it is on.. what am i missing? Have you put send and return blocks in your patch. I'm talking programming the Helix NOT physical connections. Quote Link to comment Share on other sites More sharing options...
twystedriffs Posted June 10, 2017 Author Share Posted June 10, 2017 Thanks Peter.. Guess it was a bad patch cable. Was only running it mono so wasnt getting anything! Sweet;) now if I can only get my talkbox working. I have a couple crate powerblocs around, thinking I may have to use one of em to push it! Todays experiment... Quote Link to comment Share on other sites More sharing options...
